1990 crx
1990 crx
that could be a problem with how well you bled the brakes after the swap too...
CRX91
1990 crx
Post by CRX91 »
ok the guy that im going to get them off of really dont no to mutch about the car
and i hered that its best to swap the front hf to si brakes and im going to need si brakes eny way for my b-series i think im right on that
crx08
1990 crx
Post by crx08 »
it would be a good idea to do the front brakes as well. the HF calipers are tiny. or you can use DA front spindles too for a bit bigger brakes
stl-imports.com/forums
CRX91
1990 crx
Post by CRX91 »
ok this mite sound stupid but whats da lol
crx08
1990 crx
Post by crx08 »
90-93 Integra chassis code.
CRX91
1990 crx
Post by CRX91 »
ok thats what i was thinking but i never hered that before i hered i should use a 20/40
thats integra i think or is si 40/40 but it could be the other way around
crx08
1990 crx
Post by crx08 »
the integra is 40/40 for sure. you can get those out of junkyards for cheap
CRX91
1990 crx
Post by CRX91 »
ok does the 89 hf prop valve look like the 90 hf prop valve so i can tell is he has the one i need i dont want to take an 89 prop valve that would be usles
crx08
1990 crx
Post by crx08 »
I have no idea. but there will be numbers stamped on the prop valve. that will tell you what it is
CRX91
1990 crx
Post by CRX91 »
ok thanks
