Thats why I put the "@" symbol in front of the 9.0:1 close enough.RBs93;223408 wrote: i dont know whats "extreme". shooting for 450-500whp on the new setup.
im already running 9.2:1 so spending 600bucks on new pistons to drop the compression that little bit isnt cost effective on my side. i could,as you siad mess with the head to drop the compression a tad.
yes, that does help. but you're leaving out the part where the block gets sleeved...RBs93;223464 wrote:i guess it would help if i posted the set-up:
b18b
255 pump
660cc injectors
rods
LS head
stock cams/gears
BC valves springs,retainers
water/meth kit
garrett 35r turbo
cast iron turbo manifold (ram horn when i get it finished)
new 3" charge pipe turbo-intake
you're right on the displacement...i was having a brain function failure when I typed that. And yes, those injectors are way too small for that HP level.5thgen;223465 wrote:And you cannot gain displacement by removing material in the chamber. Displacement is bore x stroke.....always. You have to mess with 81x89 to get more displacement.
I also would not want 450-500 on 660cc injectors.....unless you are running a high base pressure.
There are 2 guys down here that built 2L B's making over 500whp...if you look you'll find one of them is a member of this board still.
