z6 help
z6 help
onecam12sec;208854 wrote:look at the weight in driverside door. it should be like 3270 for si. also power sunroof. if not ,unless it's a vx(no side moldings or ps, and tach redline 6500), you will need to run wire for vtech, if not already done.
Or you could just do it the easy way and look at the VIN...:hammer:
EH3 = Civic Si
EH2 = Civic DX, CX, VX
ls hatch
z6 help
Post by ls hatch »
well this car doesnt have powersteering, but has side trim, no sunroof, drums in the rear.. im pretty sure it didnt come stock but the guy we got it from told me it was but hes lieing.. if it did the distributer wouldnt be the way it is.. and there is two plugs ones on the iac, i guess the other is for the old iac..
z6 help
ls hatch;208886 wrote:well this car doesnt have powersteering, but has side trim, no sunroof, drums in the rear.. im pretty sure it didnt come stock but the guy we got it from told me it was but hes lieing.. if it did the distributer wouldnt be the way it is.. and there is two plugs ones on the iac, i guess the other is for the old iac..
The IACV and purge solenoid both have two-pin plugs that look identical other then the wire colors. The other plug is probably for the purge solenoid which is a common emissions part that most people delete. It's probably a DX from the sound of things.
This car sounds kind of familiar. Is it red?
onecam12sec
z6 help
Post by onecam12sec »
gvwr on my 95 si was 3270 if i remember correctly. gvwr on my 92 si was 3245. and gvwr on my 92 vx is 3055.
z6 help
gvw is the max weight of a vehicle when it is loaded with passengers and cargo, not the actual weight of the vehicle.
onecam12sec
z6 help
Spork;208983 wrote:gvw is the max weight of a vehicle when it is loaded with passengers and cargo, not the actual weight of the vehicle.
i know that. take a 92 dx, and a 92 cx for example, no badges on them. pretty similar on the outside. gvwr on the door would be as follow, dx 32xx, cx30xx
z6 help
Post by HardCore97 »
my brother has a 92 dx hatch and it weighs just about 2400 with him it. hes about 300lbs. car has the carpet and sound deadening taken out otherwise its all there
Racecore.com
CRXFreak
z6 help
Post by CRXFreak »
HardCore97;209042 wrote:my brother has a 92 dx hatch and it weighs just about 2400 with him it. hes about 300lbs. car has the carpet and sound deadening taken out otherwise its all there
its a 95 and it weighed 2440 with me and a floor jack an a bunch of other random tools in it.
racecore.com
