Looking to motor swap my DA?
Rojo92hatch
Post by Rojo92hatch »
well...if i knew more about swaps...and how to do them i would help...buttt i would be more then happy to be there and watch..maybe lend a hand
justme5424
Post by justme5424 »
Rojo92hatch;181849 wrote:well...if i knew more about swaps...and how to do them i would help...buttt i would be more then happy to be there and watch..maybe lend a hand
thanks rojo92hatch, i'm just trying to get some info so i can at least get everything set up to do the swap. But when the time comes to do it, i'll be sure to let you know?
90 Honda CRX HF
-B16A Turbocharged
Digital Sol
Post by Digital Sol »
edit'
Not much of a B16 fan personally, but if you are insistant on swapping it, you can use basically everything off of your motor.... alternator, axles, mounts, transmission (although it would be better for you to find a b16 transmission), shift linkage, starter, ac will bolt up, ps may not but could probably be modified slightly to work (not sure if there are issues because of the difference in deck height), stock harness would work but you will need to run a couple wires for vtec... you will need an OBD-0 PR3 or PW0 ecu to run vtec(those can be toughish to find).
justme5424
Spork;182247 wrote:Not much of a B16 fan personally, but if you are insistant on swapping it, you can use basically everything off of your motor.... alternator, axles, mounts, transmission (although it would be better for you to find a b16 transmission), shift linkage, starter, ac will bolt up, ps may not but could probably be modified slightly to work (not sure if there are issues because of the difference in deck height), stock harness would work but you will need to run a couple wires for vtec... you will need an OBD-0 PR3 or PW0 ecu to run vtec(those can be toughish to find).
awsome, thanks so much steve. Its much appreciated.
90 Honda CRX HF
-B16A Turbocharged
Rojo92hatch
justme5424;181852 wrote:thanks rojo92hatch, i'm just trying to get some info so i can at least get everything set up to do the swap. But when the time comes to do it, i'll be sure to let you know?
ohh for sure!! i wanna learn!!! lol
justme5424
Finally got my PR3 in today, what other wires am i gonna have to run besides the ones for vtec? i've heard knock sensor and a few others need to be added also? anyone have any insight?
90 Honda CRX HF
-B16A Turbocharged
crx08
Post by crx08 »
justme5424;187536 wrote:Finally got my PR3 in today, what other wires am i gonna have to run besides the ones for vtec? i've heard knock sensor and a few others need to be added also? anyone have any insight?
here is a link that should help you out.
http://rywire.com/store/9091-integra-b1 ... 1ee5cd722e
1 for knock, 1 for 2nd O2 sensor, 2 wires for the vtec solenoid
