Looking to motor swap my DA?
Rojo92hatch
well...if i knew more about swaps...and how to do them i would help...buttt i would be more then happy to be there and watch..maybe lend a hand
justme5424
thanks rojo92hatch, i'm just trying to get some info so i can at least get everything set up to do the swap. But when the time comes to do it, i'll be sure to let you know?Rojo92hatch;181849 wrote:well...if i knew more about swaps...and how to do them i would help...buttt i would be more then happy to be there and watch..maybe lend a hand
90 Honda CRX HF
-B16A Turbocharged
-B16A Turbocharged
Not much of a B16 fan personally, but if you are insistant on swapping it, you can use basically everything off of your motor.... alternator, axles, mounts, transmission (although it would be better for you to find a b16 transmission), shift linkage, starter, ac will bolt up, ps may not but could probably be modified slightly to work (not sure if there are issues because of the difference in deck height), stock harness would work but you will need to run a couple wires for vtec... you will need an OBD-0 PR3 or PW0 ecu to run vtec(those can be toughish to find).
justme5424
awsome, thanks so much steve. Its much appreciated.Spork;182247 wrote:Not much of a B16 fan personally, but if you are insistant on swapping it, you can use basically everything off of your motor.... alternator, axles, mounts, transmission (although it would be better for you to find a b16 transmission), shift linkage, starter, ac will bolt up, ps may not but could probably be modified slightly to work (not sure if there are issues because of the difference in deck height), stock harness would work but you will need to run a couple wires for vtec... you will need an OBD-0 PR3 or PW0 ecu to run vtec(those can be toughish to find).
90 Honda CRX HF
-B16A Turbocharged
-B16A Turbocharged
Rojo92hatch
ohh for sure!! i wanna learn!!! loljustme5424;181852 wrote:thanks rojo92hatch, i'm just trying to get some info so i can at least get everything set up to do the swap. But when the time comes to do it, i'll be sure to let you know?
justme5424
Finally got my PR3 in today, what other wires am i gonna have to run besides the ones for vtec? i've heard knock sensor and a few others need to be added also? anyone have any insight?
90 Honda CRX HF
-B16A Turbocharged
-B16A Turbocharged
crx08
here is a link that should help you out.justme5424;187536 wrote:Finally got my PR3 in today, what other wires am i gonna have to run besides the ones for vtec? i've heard knock sensor and a few others need to be added also? anyone have any insight?
http://rywire.com/store/9091-integra-b1 ... 1ee5cd722e
1 for knock, 1 for 2nd O2 sensor, 2 wires for the vtec solenoid
