D-series mini me questions...
N2HIFI;125724 wrote:???? wtf? need more input on this one
y8 cam gear keyway is half tooth off than rest of the d-series cam gears. base timing on y8 is 12* unlike 16* on every other honda.
here is some good long reading for you about all of it... just too much of a headache is all it is.
http://www.homemadeturbo.com/forum/inde ... ic=59894.0
civic97hx
Post by civic97hx »
not tryin to thread jack here but can u mate a y5 head to a z6 block?
99BlackHatch
Post by 99BlackHatch »
Did you ever check Honda-Tech?
A y5 head SHOULD be able to mate up... doesn't seem like a good swap, but it should be able to be done.
SquadronOne.net
civic97hx
Post by civic97hx »
yea i checked there but i couldn't find anything on that, i just found a good deal on a z6 block and i have a bad y5 engine, well bottom end atleast, and i just wanted to get it back on the road since its damn near impossible to find a cheap enough y5 replacement engine.
99BlackHatch
The D16Y5 is just a Y7 / Y8 block, it should be a direct bolt on.
http://en.wikipedia.org/wiki/Honda_D_engine#D16Y5
The Y8 will result in the same displacement, and approx the same compression, while the Y7 will give the exact same compression.
Your choice from there, but tons of junk yards and I'm sure a couple members of this board can help you out with a good and inexpessive block.
SquadronOne.net
civic97hx
Post by civic97hx »
wow ok i guess i need to post a wanted ad then lol, well im off to work so hopefully i can do it when i get home tonight, thanks for helpin out im still learnin about all these engines and all the different possibilites
99BlackHatch
No problem, we all had to start learning somewhere.
SquadronOne.net
