A y5 head SHOULD be able to mate up... doesn't seem like a good swap, but it should be able to be done.
I'm still a neighborhoodASSHOLE!
SquadronOne.net - 1996.5 Black Acura 3.5RL - Kouki front end conversion coming... Wait. DID IT! - 2004 Carbon Gray Pearl Acura 3.5RL - Slammed, JDM headlights, Navigation, other fun stuff
yea i checked there but i couldn't find anything on that, i just found a good deal on a z6 block and i have a bad y5 engine, well bottom end atleast, and i just wanted to get it back on the road since its damn near impossible to find a cheap enough y5 replacement engine.
The Y8 will result in the same displacement, and approx the same compression, while the Y7 will give the exact same compression.
Your choice from there, but tons of junk yards and I'm sure a couple members of this board can help you out with a good and inexpessive block.
wow ok i guess i need to post a wanted ad then lol, well im off to work so hopefully i can do it when i get home tonight, thanks for helpin out im still learnin about all these engines and all the different possibilites
No problem, we all had to start learning somewhere.
