idleing problem on d series
Post by bildo16 »
spray brake clean or sumthin of the sort on your tb intake mani and all of your lines, when your idle goes down, you found your leak.
Ef-it
Post by Ef-it »
Is the coolant topped off? With certain Honda's if te coolant gets low enough it will surge at idle.
stlmadpanda
Post by stlmadpanda »
all right here was the fix. coolant wasn't low, no vacuum leaks or anything it was actually pretty obvious. i took it off a 1.8 ls. that motor needs more air at idle then a 1.5 obviouslly. so i took off the tb and broke the nut loose that holds the throttle blade open just a hair to allow for air to flow at idle, being how the idle air control valves cant let enough flow. so i back off the allen bolt closeing the throttle blade just a little. put it back together and pow. idles smoothe at a little under 1000 rpm. theres your fix.
Drowzysleeper wrote:
stlmadpanda wrote:of course she did
