Removing Tint
92_luder
Removing Tint
Post by 92_luder »
master b;260116 wrote:I 2nd the windex and trashbag. Just soak the tint on rear window with windex cover the inside of the window with black trashbag. Park in the sun for 20 or 30 mins or untill the window is hot. And the tint peals right off. Dont use a razor youll mess up the rear defroster. And DO NOT use a heat gun on your window. lol you wont have one when your done
thanks for that lol, i like my rear window lol
colten
Removing Tint
Post by colten »
I've tried this method before. The tint did peel right off but it left behind a nasty residue.
master b;260116 wrote:Dont use a razor youll mess up the rear defroster.
Obviously you didn't read my post very thoroughly...
colten;259866 wrote:Then I'd carefully use a razor blade to scrape off the residue between defrost strips and use WD40 to remove the residue on the strips themselves.
master b;260116 wrote:And DO NOT use a heat gun on your window. lol you wont have one when your done
If you melt your window with a heat gun you're either trying very hard to melt it or an idiot who shouldn't be using a heat gun in the first place.
95_gsrfodo
Removing Tint
Post by 95_gsrfodo »
colten;260220 wrote:I've tried this method before. The tint did peel right off but it left behind a nasty residue.
it will get the tint off... then the residue you go back with goo b gone or something and get the glue off...
‎4 Doors = More Whores
master b
Removing Tint
Post by master b »
actually i did. Why spend 3 hrs scrapping tint and residue off with a razor blade when you can just use windex and a trash bag. This method is very time efficient. Im just trying to save him some time. You can do it the hardest way if you want to.
And your rear window is tempered safety glass. It wont melt it will shatter. Why in the world would you attempt to heat the entire window with a heat gun. You wont get the heat evenly distributed hints why you had to use a razor blade.
and like 12 other people said use goo be gone or just use windex with the left over residue
92_luder
Removing Tint
Post by 92_luder »
im doin the windex method the next hot day we get. i seen it done so seems like the way to do....im not gonna fool around my defrosters with a razor blade...no way
