+1 and clean your damn engine bay b4 you take pics..g3integragsr;136070 wrote:looks good man, try working on your camera skills
wire relocation (oh yeah i forgot 56k or something)
xslickwhitetegx
UKDM Whore
kra95civic
ok noted then fix your post..........matt;136014 wrote:why do you think i have not done that yet i figured that out
another update
i have had so much shit going on its rediculous but squeezed in time to do some more wiring
mad pics
before (doesent show too much of what i moved)
made a bracket for my cb
did more tucking and relocating
moved the throttle cable and the criuse control dealy and injector wiring
mad pics
MyfodoSi
Lookin good. Now clean 'er.
Ribs. I had ribs for lunch, that's why I'm doing this.
singleslammer
When you tucked the Throttle cable, did you check to make sure that it wasn't going to catch on anything. Happened to me once. that is some scary stuff when you can't get the car to stop from going faster. Also, make sure that your injector wiring isn't touching anything that gets hot. It will eat through the loom eventually and that isn't any fun either.
found this out on mlk bridge i was just chillin at 6k for like 10 seconds b/t shifts then put it in third and pushed the brake and finagnled the throttle till it came loose parked at the next gas station and fixed it.singleslammer;136924 wrote:When you tucked the Throttle cable, did you check to make sure that it wasn't going to catch on anything. Happened to me once. that is some scary stuff when you can't get the car to stop from going faster. Also, make sure that your injector wiring isn't touching anything that gets hot. It will eat through the loom eventually and that isn't any fun either.
singleslammer
ouch, when it happened to me I ended up over revving the car by about 2.5K. not good since it was a Ford 3.8L v6. uuhhhh...pushrods (shudder)
