Sex Facts Friday v.5 *New Feature AND Illustrations*
PssshHondas
Post by PssshHondas »
Before I get started on this weeks edition of Sex Facts, I'll be posting up a "Position of the Week" every Friday as well. Fun, right? yeeeahhhh
These positions are mostly for the ladies enjoyment, but lets face it, guys enjoy just about any position. Lets take a moment and realize that sex feels completely different for women than it does for men, and not all positions feel as great to women as they do for men. Try em out. *Thank god I could find pictures, because some of the descriptions just aren't good enough.*
The Slow Climb
While on your back, put a pillow under your butt, lift your hips, and bring your legs up and back toward your shoulders, as though you're folding in half. This move allows him better ease of thrusting and deeper penetration — a perk for both of you. Plus, it can stimulate your G-spot. But consider this a warm-up — you're getting the zone primed for a more intense orgasm. Once your G-spot feels sufficiently stroked, put your legs down and have him get into coital-alignment-technique (CAT) position. He's on top, but he lifts his pelvic bone upward, aligning it with your clitoris. Then he rocks against the area until you peak. The legs-up position is a slow burn that brings you to the brink and increases sensitivity. Then the addition of clitoral rubbing takes you over the edge in a bigger way than if you had done CAT alone.
Homie say whaaat? Here's a pic.
Down Doggie
You've probably tried an all-fours pose before. But while mentally the doggie-style position has great bad-girl benefits, in order to make it actually orgasmic, you need to modify it a bit. Lie on your stomach, lifting your butt slightly so he can enter you. Your partner can prop himself up with his hands in a push-up position or lie on top of you. Not only does this facedown configuration provide increased friction as he moves in and out, but you can gently grind your clitoral area against the bed as well. HELLO! pic?
The Criss-Cross
With all the twisting and bending that goes on, sometimes sex can feel more like a cardio workout than a pleasurefest. That's why it's important to have at least one relaxed orgasm — inducing position in your repertoire. Such as this: While you're on your back, he should lie on his side, turned toward you. Swing both legs over his hips and thighs, making a bridge over them. Then, just let him gently thrust into you. If it takes you a while to climax, this pose is ideal. It's not very aerobic, so the sex can go on for a long time without either of you tiring out. When you want to climax, it's easy to touch yourself or he can use his top hand to stimulate you. HELLO! This position is as equally stimulating for men, because the position makes her legs stay closed, making her..umm..tighter :) heres a pic :)
Reverse Cowgirl
Ladies, dont knock it til you try it! Girl-on-top tends to be a go-to for achieving orgasm...and for good reason! It allows you to dictate the pace and depth of thrusting, but mainly, you have easy access to your clitoris. You can touch your C-spot, have him touch it, or rub against his pubic bone to achieve orgasm. But you can up the ante by literally pulling a 180. Twist around so you're pointed toward his feet in reverse cowgirl position. Instead of straddling him, put your legs together, feet flat between his legs. The benefits of this are twofold: With your legs together, the fit is even tighter, making the sensations more intense. Plus, there's increased G-spot stimulation, which combined with your own clitoral strokes, makes for an explosive orgasm. Again, this is a crowd favorite among men, and rapidly becoming a favorite for women as well. Pic anyone?
Tabletop aka AMAZING
In some cases, a simple change of scenery can aid in achieving orgasm. For this move, you'll need a kitchen table — one that comes to your man's waist. Lie down on the table with your butt near the edge. He enters you while standing between your legs, holding on to your hips for leverage. You can rest your feet on his shoulders or on the edge of the table. Because he's standing, his hands are free to stroke your body. And he's at a perpendicular angle, rather than right on top of you, making it easier for him to touch your clitoris, unobstructed. To up your odds of orgasming, clench and lift up your butt, which will increase the pelvic tension and blood flow to the area. Rawr.
Reverse Lap Dance
This one's always a fan favorite — he sits and you straddle him so you're face-to-face. You have a lot of control over the speed, angle, and motion because you can use your arms and legs to help you maneuver. Rather than just moving up and down, which can be especially tiring for you, sway forward and back, rubbing your clitoral area against him. In addition to the freedom of movement, there are a few other benefits to this booty move. "If you lean back just a little bit, you'll get greater G-spot stimulation and he'll be able to play with your clitoris. Plus, your breasts will be perfectly aligned with his mouth, adding a whole other layer to the sexual experience. I have no witty remark for this one. Just advice...Do it.
Spoon
Obviously, you know emotional attachment is essential to achieving orgasm with your guy. And there's no configuration that's more snuggly than the spoon. To assume the position, simply lie on your side, your guy scooted up behind you. Rather than move in and out, he should stay inside you, gently thrusting against the front wall of your vagina. Aside from fulfilling your cuddly needs, it provides consistent stimulation to your G-spot, which is key for achieving orgasm from intercourse. Since he may not be able to penetrate you as deeply though, guide his hand around your hot spot. And just think: Once you've both climaxed, you'll be in perfect postcoital position as well. Awwww snuggles after sex. Whodathunkit.
POSITION OF THE WEEK
The Sexual See-Saw
Probably not best for beginners, people with no coordination, or people who get dizzy easily :)
Lie on your back and lift your legs so they're over your ears and parallel to the floor. Your partner, kneeling in front of you, butts his knees up against your lower back, supporting you, and leans his torso against your thighs. (You can hold his legs to stay in this vixen-esque V-shape.)
This position will make any guy's member feel like Moby Dick, since your legs are raised (which narrows your vaginal canal) and spread (which provides the deepest penile penetration). That adds up to an extra-full feeling plus lots of fab friction for you and a tantalizingly tight squeeze for him.
Vary the pace and the intensity of the rocking. Just as one speed starts to feel unbelievable, switch it up. Go from slow to fast and back to slow again, drawing out for the climax for as long as you can. Time it right, and you'll be headed for dual-orgasm delight.
PIC ANYONE?? you betcha.
**PS**
Im not saying these are "new" or "fancy" positions, and in fact im sure most of you have tried alot, if not all of them. However, this is your WAKE UP CALL that these positions make the ladies alot happier. :)
I hate Rick.
that last one is interesting, kinda looks like one slip and her neck would crack :)
imports_only98
Post by imports_only98 »
Reverse Cowgirl
Reverse Lap Dance
/thread.
-amy
imports_only98;111478 wrote:Reverse Cowgirl
Reverse Lap Dance
/thread.
Thoes are good, but I want to try this one(I have done one like it, but it was anal sex)
This one also looks fun but technical
imports_only98
lmao too much info zach.
-amy
imports_only98;111482 wrote:lmao too much info zach.
Its never to much info when it comes to me :)
08NHBPSI
Post by 08NHBPSI »
lol wow
40 views and 7 replies, I didnt think honda kids were this prude
:popcorn:
08NHBPSI
Post by 08NHBPSI »
maybe they're just intimidated
imports_only98
08NHBPSI;111507 wrote:maybe they're just intimidated
these guys/gals??? NEVER. lol
-amy
