Random Facts
1. Foods said to “lighten” the taste of semen include kiwi, watermelon, and celery. Foods that make the taste of semen more bitter or stronger include coffee, beer, and dairy products. Finally, foods that “sweeten” the taste of semen include blueberries, plums and cranberries (the actual fruit, not fruit juice, so cranberry and vodka will not help you here)
2. Next time you have “Me Time”, try a few of these techniques proven by men to help enhance masturbation:
Pelvic thrust with wrist
This masturbation technique utilizes the wrist and hand simultaneously.
Lubricate your hand and your wrist. With your fingers facing your perineum, grip your penis from the front (with your thumb in your pubic hair. Kneel on a bed or the floor and thrust into your hand and along the wrist so your wrist rubs against the underside head of your penis.
Deep scrotum massage
The testicles are often left out while masturbating, but this masturbation technique gives you the tools to maximize this sensitive and sensual zone.
Lubricate your penis and scrotum. With your hand grasping your penis, point your index finger toward your scrotum. Your thumb and forefinger should be closest to your body. Allow your thumb and forefinger to slide down as far as they can go in a stroke toward the scrotum. Your other hand is now free to do what you will with your testicles -- be it a deep massage, tickle, etc.
Wringing
Don’t let the old washerwoman into your head. Squeeze a bit more fun out of your manhood with this stellar masturbation technique.
Lubricate your penis. Using both hands, one at the bottom and one at the top of the penis, gently wring in opposite directions. Use the motion from bottom to top as if you were wringing out a cloth -- squeeze the semen out, not in.
Butt spread
This one sounds a bit weirder than it really is, so give us a chance here. This masturbation technique may not be for everyone, but it's worth giving it a shot just to find out if it does the trick for you.
Lubrication is optional -- as you like. On a comfortable surface (bed), sit on your heels with each heel gently spreading your butt cheeks (comfortably, don't overstretch as you may cause yourself pain instead of pleasure). Masturbate as you wish, using any of the above techniques or with your usual method. When you are about to ejaculate, spread your cheeks and feel the deep orgasm stem from your perineum. (There is a pressure point in the center of your perineum that creates more intense orgasms). This masturbation technique can be quite intense.
Milking
Why did the cow wear a bell around her neck? Because her horn didn't work. Fortunately, yours does!
Lubricate your penis. Sitting in a relaxed position, using both hands one at a time, squeeze and pull up the length of your penis and over the top. If you've got extra skin (read: uncircumcised) you can also pull the extra skin up and over the head of the penis when you pull up. Repeat as necessary, and as slowly or quickly as you like.
3. The first rule of sex 101- LADIES FIRST! If you pleasure your woman correctly, and enough, the payback will be outstanding. Here are a few tips for giving women multiple orgasms:
Avoid Freud
Forget everything you learned in Psychology 101. Sigmund Freud made a name for himself demonizing the clitoris and formulating a truly kooky view of women’s sexuality. Freud got the idea into his head that the clitoris was an immature source of sexual pleasure, a mere launching pad for the more mature vaginal orgasm, which, of course, could only be produced via genital intercourse. At the end of his life, Freud acknowledged his incomplete understanding of female sexuality and said, “If you want to know more about femininity, you must interrogate your own experience, or turn to the poets, or else wait until science can give you more profound and more coherent information.” Or, for today’s modern guy, just turn to the woman in bed next to you and deploy some basic cliteracy.
Ladies first
When it comes to satisfying a woman, a little old-fashioned chivalry goes a long way. Lest you think the importance of such courtesy is over-exaggerated, direct your attention to Lorena Bobbitt who, when questioned by police as to why she cut off her husband’s penis, responded, “He always has an orgasm and doesn’t wait for me. It’s unfair.” Need one say more?
The simple fact is that the male orgasm typically comes easy. Masters and Johnson dubbed it “ejaculatory inevitability” and the late Dr. Alfred C. Kinsey declared that 75% of men ejaculate within two minutes.
Is it any surprise, then, that researchers from the University of Chicago declared in the 1994 Sex in America Survey that men reach orgasm during intercourse far more consistently than women do, and that three-quarters of men, but less than a third of women, always have orgasms? This means that more than two out of three women on average are consistently denied their climax -- good reason to start hiding the cutlery.
Studies such as those by Kinsey and Masters & Johnson have concluded that, among women whose partners spent 21 minutes or longer on foreplay, only 7.7% failed to reach orgasm consistently. That’s a shift of tectonic proportions, from two out of three women not being able to reach climax to 9 out of 10 achieving satisfaction, all due to a matter of minutes.
So take the path of the true gentleman: Postpone your pleasure. As Sir Thomas Wyatt wrote, “Patience shall be my song.”
Think outside the box
Rare is the man who boasts in the locker room, “I made love to her as subtly and lightly as a feather” or, “I grazed her vulva as with the delicate wings of a butterfly.” Yet such language would be appropriate, since the inner two-thirds of the vagina are substantially less sensitive than the outer third. So think outside the box (pun definitely intended), but know that the clitoris is extremely sensitive to physical sensation and needs to be properly prepped for serious stimulation. Avoid her genitals and go easy on the breasts for a good 10 to 15 minutes.
Develop a clitoral compass
When embarking on a journey of female sexual response, know your way around her vulva -- from the northern tippy-top of the clitoral glans (the “love-button,” so to speak), to the western and eastern boundaries of the labia minora (her inner lips) to the southernmost regions of the perineum (the smooth expanse of skin just below the vaginal entrance) and anus.
Stop thinking of the clitoris as a little bump, and start thinking of it as a complex network, a multiple orgasm-producing pleasure-dome, the Xanadu at the heart of female sexuality. With over 8,000 nerve fibers, the clitoris has more of them than any other part of the human body and interacts with the 15,000 nerve fibers that service the entire pelvic area. As science writer Natalie Angier describes the clitoral network, “Nerves are like wolves or birds: If one starts crying, there goes the neighborhood.”
Let your fingers do the walking, and don’t stop talking
That advice comes from one of my female patients, who told me that some of her best orgasms came while receiving manual stimulation from her boyfriend as he simultaneously stared into her eyes and talked dirty. I won’t put words in your mouth (you can use your imagination for that), but I will tell you to rest comfortably on your side, place your hand over her vulva, and press against her pubic mound with the base of your palm.
Let your fingers drape against the full expanse of her vulva like a thick curtain. Let her push against your palm, and use your index and middle fingers to make rhythmic upside-down "come hither" gestures along her vaginal entrance. Lightly stimulate her clitoral glans (the head) with your fingertips. For variety, reach in and up with two fingers and press them against her vaginal ceiling as though you were lifting her up off the bed, an ideal way to simultaneously stimulate her clitoris and G-spot.
The tongue is mightier than the sword…Indeed, the tongue is a powerful tool, but not when used like a cobra lashing out at a mongoose. As one woman confessed, “Every time my boyfriend goes down on me, it’s like the running of the bulls in Spain -- a mad stampede for the clit and I just want to get out of the way.”
When it comes to conversing in the language of love, cunnilingus should be every man’s native tongue. Oral sex can be an excellent method for multiple orgasms. Even porn star Ron Jeremy, in possession of the famous 10-inch member, observed, “More women have gotten off with my tongue than with my penis.”
Once found, a skilled cunnilinguist rarely goes unappreciated. But if you’re not sure exactly how, just press a flat, still tongue against her vulva and let her do the work. It’s the cunnilingus equivalent of letting her get on top.
One of my favorite tongue techniques is the “Rope-a-dope”: Let her push and grind against your flat, still tongue -- take it all in -- and then spring back with a series of fast vertical and diagonal tongue strokes. Lick her senseless with a short burst of energy and then return to the flat, still tongue, waiting for yet another opportune moment to spring to life again.
Try licking her with the skill of an experienced painter: broad strokes, with pinpoint targeted precision. Swoop serpent-like, starting with the flat part of the tongue and ending with the tip. Be sure you know what you’re aiming for; demonstrate the precision that underlies the passion.
Learn how NOT to make love like a porn star
Irrespective of Jenna Jameson’s best-selling admonition, take the pressure off and think of your penis as just another tool in your sexual survival kit. Focus on shallow thrusts. In the standard missionary position (you on top, her beneath you), use the tip of your penis to barely penetrate her vaginal entrance. Let your penis rest just inside her. (If you’re uncomfortable in the missionary position, simply kneel or sit in front of her vulva). Linger. Loiter. Meander. Stay close to the entrance.
Press your thumb against her clitoral head and gently flick it from side to side as you penetrate her with your short, shallow thrusts. Or press the shaft of your penis against her clitoris and gently thrust between the folds of her labia without ever entering her. When you thrust deeply, press your pelvic bone against her clitoris and hold the position before withdrawing.
Get into the 90-second window
Before shifting from genital penetration to orgasm, use manual and oral stimulation to bring her as near as possible to the point of orgasmic inevitability.
Cunnilinguists are in a great position to observe the visible signs of arousal, especially when the lights are on. Of particular note will be the darkening in color and deepening in luster of her inner labia and the retraction of the clitoral head into its hood, both signs that she's within 90 seconds of reaching climax. Even in the dark, it's not hard to observe when the glans has retracted; focus on feeling the head when it's fully protruded and erect, and you'll easily be able to recognize its absence.
Once she’s in the 90-second window, try the female superior position (woman on top). An excellent method for multiple orgasms, this position is ideal for her to: Position her clitoris against your pubic bone at the base of your penis and achieve the ideal amount of pressure; stimulate her clitoris against your penis; control rhythm and pace; and modulate the experience of orgasm.
Or try the Coital Alignment Technique (CAT). This sexual position is designed to greatly improve a woman's chance of orgasm through genital penetration and enhances the standard missionary position. During CAT, the man penetrates from a higher angle than usual, placing pressure on the woman's clitoris with the base of his penis and pubic bone. When performing CAT, the main thing to keep in mind is to maintain contact with the clitoris. The overall movement is much less a thrusting than a synchronized rocking back and forth, with the focus on the clitoris and the base of the penis.
OK, we’ve been touching on it, now let’s hit it directly
Fortunately, the G-spot, named after German doctor Ernest Grafenberg, is really more of an area than a single spot. Located atop the vaginal ceiling, with the diameter of a small coin, you can actually feel it swell during arousal. The G-spot responds to firmer stimulation than the clitoris, and though its stimulation will very likely enhance or deepen clitoral satisfaction, that won’t happen independently of the clitoris. Some of the latest research even suggests that the G-spot is nothing more than the back-end roots of the clitoris.
That brings us to the point that the most satisfying orgasms are the ones that combine clitoral and G-spot stimulation, also known as the blended orgasm. Focus on simultaneously stimulating the surface of her vulva and her upper-vaginal ceiling. Some time-proven combinations for producing blended orgasms that respectively stimulate her clitoris and G-spot include tongue-fingers, tongue-vibrator, and fingers-vibrator.
You might be thinking, with all of these various roads to orgasm, which is the one best traveled? All women have the innate capacity to experience multiple orgasms, and many realize this potential during masturbation. As Natalie Angier has written of the female orgasm, “It may take many minutes to reach the first summit, but once there, the lusty mountaineer finds wings awaiting her. She does not need to scramble back to the ground before scaling the next peak, but can glide like a raptor on currents of joy.”
4. THE TOP 10 FETISHES
10. Stomachs
Men and women both agreed that taut tummies make them somewhat crazy. But others said that they would never bed a potential partner if their tummies protruded or hung loosely.
Some guys weren't as picky and admitted that they liked it when a woman had a tummy with a teensy-weensy little pot. One gentleman was very adamant about needing to release himself on a woman's stomach or his experience simply wouldn't be pleasurable.
9. Body piercing
This one was quite popular with the younger crowd (18-35). Everything from bellybuttons, tongues and nipples to eyebrows and penises was not only acceptable, but for a specific few, it was a prerequisite.
One guy told us that he loves tongue rings because after being pleasured by a girl who had one, he couldn't go back to the "ordinary." The feeling of the cool object rubbing against his penis while her hot mouth engulfed him "felt like heaven.
8. Latex, Vinyl, and Leather
Men seem to love material; perhaps not the actual feel of it, but the rather pornographic quality it gives to a sexual encounter. Although men look to settle down with a sweet woman, most will forever have a fixation with that "bad girl" look.
"Watching a woman move around in anything tight and shiny is a tease in itself," says one gentleman. Another man told me that his girlfriend's entire wardrobe consists of latex and leather.
7. Domination and submission
To my amazement, most women dominate and most guys submit. HELLO! A lot of women said they love to order their men around in bed like slaves and spank them, smack them, and even penetrate them with a strap-on.
Guys, on the other hand, enjoy submitting to women and being told what to do. I guess most of them are probably tired of performing all the time. Everything I mentioned that the women do -- well, the men enjoy having those things done to them. Welcome to the new millennium.
6. Feet and hands
You knew this fetish was coming didn't you? Men enjoy licking, sucking, kissing, and biting women's feet almost exclusively. Some guys simply can't date a woman if she has ugly feet or toes.
Women, I was surprised to learn, love to suck on men's fingers and some can even orgasm off that alone. "There's something about pleasuring a man's finger as though it was a penis that gives me orgasmic pleasure," said one woman from Seattle.
5. Fingernails and lipstick
It's the cliche of the '80s: red lipstick and long, red-lacquered fingernails. Well, guess what? Some guys are still obsessed with that whole thing. They enjoy feeling a woman's nails running down their backs.
As well, they like kissing a woman and smudging her lipstick all over both their faces. Why? Because it gives them the feeling of having adulterated sex, i.e. sex with a prostitute.
4. Braids, ponytails, pigtails
Hair, it's no surprise, was a very big fetish among guys. Blond, brunette, redheaded, braided, long, short, thick, curly, straight... you name it, they thought of it. But braids, pigtails and ponytails caught my attention. I have two theories as to why some men are into pigtails.
First, they have a preference for younger women (to say the least) and because of the illusion that pigtails and ponytails emanate, the fetishists feel as though they are fulfilling their desires.
Second, when the hair is tied up in these various ways, it could resemble a whip, to a certain extent. "Women can whip me with their hair: the ultimate turn-on." said one man from Boston. I can definitely see the latter example as working.
Some women have a fetish involving no hair: bald men. They love rubbing a man's bald head whilst in a passionate embrace. Did you hear that Costanza ? You're actually preferred by women.
3. Water
Believe it or not, many variants of water were popular with both men and women. Many women declared that they enjoyed sex best when they could hear or be in running water. Whether it be rain, the shower or even an opened faucet -- so long as they heard water of some sort.
Although it's not exactly water, many women (and some men) absolutely obsess over thunder and lightning. "The powerful sound and the sudden flashes of light give my body a feeling of empowerment. My husband and I make plans to meet whenever we know that a storm is in effect," said a woman from Colorado.
2. Golden showers
I know this one doesn't sound very inviting, but it was a popular one. Some guys love to watch a woman urinate on them as a method of foreplay. Other guys like to relieve themselves on women before they can actually get down to business.
Why? Well, the reason for this also deals with submission. Being peed on is somewhat degrading and if you allow someone to do it to you, then you're submitting and if you do it to someone else, then they are succumbing to you.
1. Voyeurism and exhibitionism
A lot of guys admitted that they couldn't get off with their partner unless they were watching pornography or another couple in the act. Even if they witnessed two people having sex or caught some erotic movies on television accidentally (yeah, right) when not with their partner, they had to masturbate.
Only a minute amount of women admitted that they are voyeuristic to the point where they needed to see sex whilst engaging in it. Oddly enough, however, quite a few women like being watched . One woman from New Orleans wrote, "I make sure to open the blinds fully before I make love with my partner."
Sex Fact Friday v.3
g3integragsr
imports_only98
Sex Fact Friday v.3
but TOTALLY filled with good information! take a few minutes and actually read it. the ladies will thank you.g3integragsr;108881 wrote:alright.....................this one is a bit wierd................
-amy
Sex Fact Friday v.3
Woo Hoo 3 of the 10 ten fetishes...
Over time I have learned that LADIES FIRST is the best way to go. that way if your having a "bad day" at least the lady still got hers, and she will be happy.
MyfodoSi
Sex Fact Friday v.3
I've never quite understood the fun behind golden showers, but there's a really funny Boondocks episode about it.
