runsonrice has a B16a 92-95 obd-1 rhd engine harness btw, He couldn't use it when he got his swap cause the everything was backwards and we woulda had to cut and extend everything.
I'm sure he'd sell cheap, since your fuse box under the hood and whatnot will have to be cut and rewired.
It should all be plug and play since everything on the passengerside under the hood will be going on the drivers side if ya understand what I'm saying.
94 Civic Coupe Ej1 "Burt" DDMTuning/PIC/Function and Form/ASR/Blox...
Yea I am kinda on a budget now the next thing I am getting is recaros. But yea i have to filp the ls harness upside down and extend the wires that need it
thebodyman;225313 wrote:Yea I am kinda on a budget now the next thing I am getting is recaros. But yea i have to filp the ls harness upside down and extend the wires that need it
I wonder if you could just use that harness, the integra is obd-1 isn't it I mean the only plugs you would have left over are for the vtec noid and purge.
