Junk yard run...
ludeboy
Junk yard run...
Post by ludeboy »
So Pick and pull has nothing, Speedway has a cpl high mileage y8's with no ecu's. The yard right next to pick and pull has a high mileage b18a1 and a y8 with no ecu and no gauge cluster but the valve cover was painted and the ex mani was cracked so I pretty sure it was beat down. All and all not much out there downtown.
Junk yard run...
PnP has a b18a1... that someone pulled out of the car and left sitting with the vc taken off, cams removed and used to prop up the hood of the car next to it, cam caps and rockers all over the ground, and mains and rod bottoms removed and left to rust on the ground. so yeah.... just sitting on its crank in the gravel. i did get some sensors and stuff i needed off of it, but nothing substancial.
ludeboy
Junk yard run...
Post by ludeboy »
Spork;101740 wrote:PnP has a b18a1... that someone pulled out of the car and left sitting with the vc taken off, cams removed and used to prop up the hood of the car next to it, cam caps and rockers all over the ground, and mains and rod bottoms removed and left to rust on the ground. so yeah.... just sitting on its crank in the gravel. i did get some sensors and stuff i needed off of it, but nothing substancial.
Yeah that pisses me off btw. At speedway some fag pulled just about every valve cover and left it off along with leaving the hood up. If the head was good originally it sure the hell isn't after weeks of weather.
Junk yard run...
i need to go back for a few sensors, and I still need to find a 90-91 hatch (Si preferred)with a black/grey interior, and a gold hatch to get some parts off of...
ludeboy
Junk yard run...
Post by ludeboy »
Dude I have been looking for a grey SI interior for years now... I found the d16a1 in a teg at speedway that I needed but the dizzy was gone grrrr. Also found 3 hoods our color but all were busted scratched or bent.
Junk yard run...
Any of you guys walk through the ford section, I need some 302 parts :)
Junk yard run...
there is supposed to be a yard full of Si's out in like warrenton... I haven't been there tho
deetz
Junk yard run...
Post by deetz »
theres a few other junkyards over this way with many hondas in them
~chris~
-scca setup 99 grand am gt
-85 cj7
ludeboy
Junk yard run...
Post by ludeboy »
I heard it was in wentzville. Sounds to me like its the fountain of youth. Everyone has heard of it but no one has found it lmfao.
Sry btlfed, didn't run by the ford section. My ford is finally finished (that is until I break it lol).
ludeboy
Junk yard run...
Post by ludeboy »
Deetz hook me up with some junkyard names and locations man. I will hit them up this saturday.
