Tire balance near Disaster-WTF!
They can also static balance your wheels where they only put the hammer on weights on the inside lip of the wheel.
RSXSLVR79
Already fucking happened! I just looked at the wheels to see if they were still there-about half of the weights on each wheel are long gone-left behind sticky residue from the stick tape.ludeboy;78517 wrote:Put some silicone on those weights though, most of the time the lazy fucks don't clean the wheel before they stick them on causing them to fall off in a few days.
Fuck Midas!
01 S2000 (Stock...for now)
RSXSLVR79
RyanA;78526 wrote:They can also static balance your wheels where they only put the hammer on weights on the inside lip of the wheel.
I will go to dobbs to have this done i think.
Kage87
go and get you're money back, or have them redo it or something
-Kyle
"Le Bon Temps Viendra"
good luck getting those off without screwing up your wheels, cause you come to my shop with sticky weights siliconed on, they are coming off one way or another.ludeboy;78517 wrote:Put some silicone on those weights though, most of the time the lazy fucks don't clean the wheel before they stick them on causing them to fall off in a few days.
Lawl, bill dont fuck around!! And he has toolz!bildo16;78576 wrote:good luck getting those off without screwing up your wheels, cause you come to my shop with sticky weights siliconed on, they are coming off one way or another.
RSXSLVR79;78569 wrote:I will go to dobbs to have this done i think.
And mine is not the only horror story I have heard from dobbs. Many other people have had similar issues. Honestly I have had better luck with walmart.btlfedgolf;78369 wrote:Same shit happened to me at dobbs, but I found out when iu was doing about 70 on 170 in traffic it started to vibrate really bad.
ludeboy
Flat blade screwdriver? Then a little bit of MEK. Shit ain't hard man.bildo16;78576 wrote:good luck getting those off without screwing up your wheels, cause you come to my shop with sticky weights siliconed on, they are coming off one way or another.
-wont that throw off the balance of the wheel?
Nah, just put a dab on to cover around all the edges. Enough to keep the weights on.
