gsr gauge cluster
Liquor Assassin
gsr gauge cluster
Post by Liquor Assassin »
just got it all wired up, everything works great, just need to run the vehicle speed sensor wires from the tranny through the firewall and in to the gc and i should be all set... pics when i get the cowling back on
gsr gauge cluster
Post by Gunmetal Si »
pics bitch
Liquor Assassin
gsr gauge cluster
ask and you shal recieve
still needs a little leveling and stuff, i just stuffed it in there untill i can start working on it again when i get back from the cruise
now, if i could find some indiglo gauges with a white face
civicex442
gsr gauge cluster
Post by civicex442 »
Looks good. I have always wanted to do this. Your righ, some blue black lighting and white face with a carbonfiber bezel would make that look bad ass!
98 EJ6
03 WRX
gsr gauge cluster
Liquor Assassin;76682 wrote:just got it all wired up, everything works great, just need to run the vehicle speed sensor wires from the tranny through the firewall and in to the gc and i should be all set... pics when i get the cowling back on
i am curious on how you can use a electronic VSS speedo on a mechanical style tranny?
and if you put indiglo gauges on that cluster i am going to stab you.. i mean come on how gay do you really wanna be?
gsr gauge cluster
N2HIFI;76712 wrote: and if you put indiglo gauges on that cluster i am going to stab you.. i mean come on how gay do you really wanna be?
+1 please dont ruin that cluster and btw thats a LS not a gsr bc a gsr redlines around 8200 not 6800. But none the less it looks good man.
g3integragsr
gsr gauge cluster
Post by g3integragsr »
soundqjr;76721 wrote:Btw thats a LS not a gsr bc a gsr redlines around 8200 not 6800. But none the less it looks good man.
Aj is right, that is not a GSR cluster. Regardless, it looks badass
andyjt
gsr gauge cluster
Post by andyjt »
N2HIFI;76712 wrote:i am curious on how you can use a electronic VSS speedo on a mechanical style tranny?
Swap out the cable driven sensor. and put in the electronic VSS. Wire up power and ground and signal goes to the gauge cluster.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
gsr gauge cluster
Liquor Assassin;76698 wrote: now, if i could find some indiglo gauges with a white face
And now I've lost all respect for you and your car.
gsr gauge cluster
andyjt;76730 wrote:Swap out the cable driven sensor. and put in the electronic VSS. Wire up power and ground and signal goes to the gauge cluster.
ahh that makes sence.. did not know that they were interchangable.
interesting hummmmm.
