what ecu is this?
J8k'S CRX
what ecu is this?
Post by J8k'S CRX »
90CivicEx;60681 wrote:So it's a obd-0 block with a obd-1 head? I do beleive the obd-0 came with just PR3 stamped on it and the obd-1 Came with PR3-1 or PR3-2 depending on if the head came off a B16a1 or B16a2.
it's not an a1 or a2 it just an a. it's a jdm motor. it's SiR II. but i am starten to think it's all mixed up and a deffent hybrid.:partydance:
:stick:
JZO6ETR
what ecu is this?
Post by JZO6ETR »
If its just an "A" then it's a first gen Sir,
Bitch I Might Be!
what ecu is this?
Post by 90CivicEx »
JZO6ETR;60694 wrote:If its just an "A" then it's a first gen Sir,
I'm talking about the head, mine is just PR3 = OBD0 and PR3-1 = OBD-1...
what ecu is this?
Post by 90CivicEx »
http://www.honda-tech.com/zerothread?id=898679
There ya go, you have a obd-0 block and a obd-1 or a obd-2 head. Nothing bad but I just always heard weak storys about the SIR1 and SIRII heads cause supposebly the ports are a bit smaller then the SIR head.
Also I can't confirm what I've heard but maybe something to gather a convo on ya know.
J8k'S CRX
what ecu is this?
Post by J8k'S CRX »
then whats the second gen?
:stick:
what ecu is this?
Post by 90CivicEx »
J8k'S CRX;60705 wrote:then whats the second gen?
B16a = OBD-0, B16a1 = OBD-1, B16a2 = OBD-2, then it goes into the ITR and CTR motors.
what ecu is this?
Post by Gunmetal Si »
from what i understand, the b16a head casting has been the same since day one it wasnt changed. itr and ctr heads are also that casting done up with a little hand porting. but ive owend all of them even a 92-93 gsr head., so jsut call me a b-series homo....
what ecu is this?
Post by 90CivicEx »
GUNMETAL SI;60707 wrote:from what i understand, the b16a head casting has been the same since day one it wasnt changed. itr and ctr heads are also that casting done up with a little hand porting. but ive owend all of them even a 92-93 gsr head., so jsut call me a b-series homo....
Meh read that forum on honda tech, the head casting number changes through the obd's. My head just says PR3 on it which is for 88 to 91 and PR3-1 is 92 lxi and up to 95 supposebly, and so on and so on.
I'm not 100% sure on this, I'm just going off the research I've been doing. I can deffinatly say if he had a mild tune like I have he would run alot better but you can't do much tuning for just bolt on's.
Wish you coulda came to dyno day so we coulda seen how much power you put out, I put out decent #'s for really no mod's at all. Actually alot of people did.
what ecu is this?
90CivicEx;60706 wrote:B16a = OBD-0, B16a1 = OBD-1, B16a2 = OBD-2, then it goes into the ITR and CTR motors.
wrong.
b16a1 is a european release 88-92 civic vti, and also the japanese 90-91 siR
b16a was in numerous civic and integra releases usually refered to as a jdm block or the p30
yo also forgot the b16a3 which was in the del sol.
what ecu is this?
90CivicEx;60709 wrote:Meh read that forum on honda tech, the head casting number changes through the obd's. My head just says PR3 on it which is for 88 to 91 and PR3-1 is 92 lxi and up to 95 supposebly, and so on and so on.
i dont make no power, lol. thats whta the b20 is for. as far as the castings, this was info that i got from a honda tech of over 20 years. even the 92-93
B17 that was int he gs-r teg was still a b16 head.
yes the head casting numbers changed, but th actuall cast did not.
