Anyone know a thing or 2 about the ZC?
Post by budget_crx »
i was afraid the pistons were touched, did the machine shop calculate the compression after installing them? ZCs have a much larger combustion chamber volume than all the other D series, which is why the OEM pistons are so domed. If the pistons installed were not ZC-specific there could be a possibility that your compression ratio has dropped significantly.
