wheels rubbing
CourtesyFlush
wheels rubbing
Post by CourtesyFlush »
so got 16x7.5 wheels and they are rubbing on my drop. they r not even tire tucking, but every bump or turn, it smells like burnt rubber and r rubbing like crazy. Any simple plan of fixing it? Should i just let it rub the surface off? im sure everyone else with larger than stock tires and a drop has had to deal with this. suggestions please. thanks
wheels rubbing
What size tires are you running? Depending on where it's rubbing at, most likely it can be fixed with a fender rolling or BFH.
CourtesyFlush
wheels rubbing
JustRob;199527 wrote:What size tires are you running? Depending on where it's rubbing at, most likely it can be fixed with a fender rolling or BFH.
205/55R16 91H
sry, but whats BFH? and how hard is it to do both the fender rolling and BFH?
wheels rubbing
95acuraintegra;199528 wrote:205/55R16 91H
Ignore the second part, the tires are your problem. You have the wrong tire size. You need a 205/45-16 tire. You won't need a fender roller or Big Fucking Hammer once you fix that problem.
CourtesyFlush
wheels rubbing
JustRob;199529 wrote:Ignore the second part, the tires are your problem. You have the wrong tire size. You need a 205/45-16 tire. You won't need a fender roller or Big Fucking Hammer once you fix that problem.
so im guessing the person i bought em from just put the wrong ones on? that makes me feel better. u know of n e one thats selling some cheap tires in that size cause i dont wanna pay the fucking 35% import tax now. lol
wheels rubbing
discounttire.com
B16inside
wheels rubbing
Post by B16inside »
make sure all jazzy essentials of lowering are taken care of alignment camber correction blah blah blah or you will be going through these pretty little tires as quick as i was. it sucks trust me
96 swapped dx coupe
da9teg
wheels rubbing
Post by da9teg »
i think he's right. you have too much tire. with a 15" i would expect to run a 205/55 , but not with a 16", 205/45 should be a lot better.
CourtesyFlush
wheels rubbing
thanks everyone for the help. im gonna just raise my coilovers to just below stock height for now to correct the issue and once i get the tires, ill lower it back down.
modthesol
wheels rubbing
Post by modthesol »
hey, you got the wrong size tire bro!
