My car passed using Acetone, and a friends passed using Rubbing Alcoholsharpie;45284 wrote:really did it work. i tryed e85 ethonal to try and pass and it worked to well and my car didnt put out enough emissions to be tested anymore so it still failed
Acetone + gas = better mpg, more power, and better idle.
99RedCivic
I've heard of people doing this to help pass emissions and it seems to help.btlfedgolf;45290 wrote:My car passed using Acetone, and a friends passed using Rubbing Alcohol
-Lucas
shinigami
kinda makes you wonder why we aren't running on the cleaner fuels to start with...
90% of Honda drivers are ricers, 5% are idiots, 5% are tuners... 100% are broke.
I need RE960's best all weather tire ever...
tmarsh
Probably because that stuff will eat through your factory fuel lines, unless you're driving a "flex-fuel" car from Ford or whoever else is making them these days.
'98 Grand Am: Wider is Better!
99RedCivic
Because it would cost more money to upgrade the parts.shinigami;45566 wrote:kinda makes you wonder why we aren't running on the cleaner fuels to start with...
-Lucas
