H2b
andyjt
H2b
freakchris03;43711 wrote:For who knows what this is...whats all the hype about it? i hear of more and more people doing it? i wonder if it would be worth it. What do you people say?
Hype about it? Makes a h-swap sooo much easier. Allows the use of a shorter geared transmission oh a h-swap, eliminates shifter cables for rods. Also allows for more room a b-series transmission is alot smaller than an h, all well as much more durable, and a lot more aftermarket parts to upgrade upon.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
ludeboy
H2b
I have no first hand experience but from what I have heard its seems that the B series trans are a bit weaker than the H series.andyjt;43717 wrote:Hype about it? Makes a h-swap sooo much easier. Allows the use of a shorter geared transmission oh a h-swap, eliminates shifter cables for rods. Also allows for more room a b-series transmission is alot smaller than an h, all well as much more durable, and a lot more aftermarket parts to upgrade upon.
