Rear disc conversion on civics???
teg_timmyc
does anyone know if i need to swap master cylinders too? or will the old one work??
I ROCK FACE-V.15245654354684
recomennded not necsassary
teg_timmyc
are they just not as powerfull? im trying to decide weather i want to do the conversion on a paying customers car or not. it all pretty much bolts right on, correct?
ludeboy
Depends on which car you got the trailing arms from. Civic yes, Integra you reuse the upper mounts from the civic. Si, bolts right on. I would def get the MC. Stock they are 13/15's, prelude and integra are 15/16 along with a EX, GSR is 1 inch. It will basically stiffen up the pedal a bit. Just make sure you get a non abs MC, also you may have to twist the hardlines to make them fit, not that big of a deal just be slow and careful.teg_timmyc;39672 wrote:are they just not as powerfull? im trying to decide weather i want to do the conversion on a paying customers car or not. it all pretty much bolts right on, correct?
teg_timmyc
how much should i charge for the rear disc setup and labor?
i was thinkin about $450 to $500 (not a friend)
sorry to hijack but I love your avatar teg_timmyc
it depends if the bolts are going to be snapping offteg_timmyc;39680 wrote:how much should i charge for the rear disc setup and labor?
andyjt
or how many bushings are going to spin out06sik20z3;39690 wrote:it depends if the bolts are going to be snapping off
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
teg_timmyc
good call guys!! but what would you charge just a random person to do this job?
teg_timmyc
thanks!! i love it alsosoundqjr;39689 wrote:sorry to hijack but I love your avatar teg_timmyc
