Im wanting to borrow an obd2 ecu. i thought one of my injectors was bad but it turns out its not the injector and it could be a ground for the clip for the injector or possibly the ECU. So does anyone have one i can borrow for like 2 minutes to plug it up and check to see if that is the problem?
K thanks bye
WTB: OBD2 Integra ECU
andyjt
Silver Knight;28835 wrote:Im wanting to borrow an obd2 ecu. i thought one of my injectors was bad but it turns out its not the injector and it could be a ground for the clip for the injector or possibly the ECU. So does anyone have one i can borrow for like 2 minutes to plug it up and check to see if that is the problem?
K thanks bye
I have a 00 one you can borrow, but im not sure if it will work since it has an immboilizer
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
Silver Knight
i just need to borrow one for like 10 seconds to see if its the ecu that is wrong with my carandyjt;28841 wrote:I have a 00 one you can borrow, but im not sure if it will work since it has an immboilizer
DC5
andyjt
Silver Knight;28853 wrote:i just need to borrow one for like 10 seconds to see if its the ecu that is wrong with my car
Thats fine, just not sure if the car will even start with the immobilizer in the ECU
Otherwise your welcome to borrow it as long as you like, i just need it back.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
