what to do..
honda_girl_88hf
what to do..
so im getting a b18 sometime in the next week or two... im also getting 900$ for another car of mine. what should be my first mod to the new motor? i was thinkin pistons maybe.. the motor is completely stock. and i want to add some stuff before i put it in. what'd you suggest??
RIDES..:honda:
2002 RSX-S
1988 CRX HF
stock and slow!
what to do..
Clutch and flywheel.honda_girl_88hf;25949 wrote:so im getting a b18 sometime in the next week or two... im also getting 900$ for another car of mine. what should be my first mod to the new motor? i was thinkin pistons maybe.. the motor is completely stock. and i want to add some stuff before i put it in. what'd you suggest??
Silver Knight
what to do..
pistons, cams, valves, header, just really depends on what goals you want to achieve.
DC5
honda_girl_88hf
what to do..
well eventually, i want to go turbo.. so building up to that
RIDES..:honda:
2002 RSX-S
1988 CRX HF
stock and slow!
what to do..
If you want to do internals right you will need to do more than $900 worth of work.
Pistons + rods + balancing + Machining > $900
Silver Knight
what to do..
well then get low compression pistons; forged internals. what kind of numbers are you wanted to see?honda_girl_88hf;25952 wrote:well eventually, i want to go turbo.. so building up to that
DC5
what to do..
sell the b18 and get an a6, z6, ac, or y8 and then swap one of said motors into car. buy a clutch and flywheel and then piece together a homemade turbo kit. you can have that car running high 13's for under $2000
honda_girl_88hf
what to do..
not sure, and i know it will take more than 900, like i said its a "project". anyway i would like it to eventually run 13s
RIDES..:honda:
2002 RSX-S
1988 CRX HF
stock and slow!
honda_girl_88hf
what to do..
well i got to work with what i have.. all im asking for is suggestions.
RIDES..:honda:
2002 RSX-S
1988 CRX HF
stock and slow!
