wtf is wrong with my car suspension?
irevto9k
Post by irevto9k »
well it seems like every other month i have to take my car in and wait an hour or so to get a stupid alignment because the toe and camber keeps on getting messed up? Does anyone have any suggestions as to why this is happeing? posssibly bad camber kit i dont think i have bent suspension peices cuz ive never hit anything and i think the alignment place would have said something about it...im just gonna buy the three year alignment so it doesnt really matter but i would like to fix the problem the right way instead of gettting tons of alignments. i talked to the previous owner he said that he had the same problem so im lost..
F>B+K ALL DAY :respect:
JonDubya
Post by JonDubya »
Details of suspension that isn't stock, please.
1997 AIGSR.
Fucking eh cotton!
irevto9k
Post by irevto9k »
its dropped on comptech springs and it has rear camber kits and camber bolts in the front
andyjt
Post by andyjt »
probaly try taking it to a different place, obviousley they cant do it right:)
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
JonDubya
Post by JonDubya »
what size drop? Can you justify the use of the camber kits? If you don't need them, remove 'em and see if that fixed the problem.
1997 AIGSR.
Fucking eh cotton!
irevto9k
Post by irevto9k »
like 1.5 in the front and 1.4 in the rear i think i do need them to much tire wear on previous car without them
JesSi
Post by JesSi »
Rsx03S;18289 wrote:like 1.5 in the front and 1.4 in the rear i think i do need them to much tire wear on previous car without them
Off topic, but i'd like to ride in your car sometime soon to see how I like the Comptech springs.
TurboFreak
Post by TurboFreak »
after you get it alinged check your suspention and make sure everything is tight...when i got mine done i drove it home and checked my camber kit and they didnt tighten some of the nuts on the rear kit. so they might be backing out over time.
Nik
Turbulent Motorsports
I have more torque than GOD!
Sleepy Civic DX
Post by Sleepy Civic DX »
maybe they are not getting your camber kit tight enough. A lowered car's suspension is jolted a lot more when you go over bumps maybe its coming loose. Or maybe you have a loose front end part. if you want to drive down to webster groves my alignment tech will take a look at it for you. he is the best in the company (dobbs).
2009 Black Mugen Fit- Slow
RSXSLVR79
Post by RSXSLVR79 »
well, if it means anything, my 06 type S was out of alignment after 10k miles. The dealer fixed that under warranty. I thought that was insane that it went out that quick. I think something was loose because the car is feeling tight as $%#@ right now :worthy:
