does anyone have an extra bolt laying around???
HondaChild
Post by HondaChild »
I snapped the bolt that connects my rear brake drum to the upper control arm, so now I need one. as well as some tip on how I should go about getting the snapped bolt out of there. any help will be greatly apperated(sp?)
this is the location of the bolt.
picture of the shaft
head
ImageUnder RE-construstion
Know your roots.
99BlackHatch
Post by 99BlackHatch »
Get on the back of it and break the "welded" nut off... Go to home depot and get a matching nut and bolt for what you need and hell while you're at it, get money somehow and buy LCAs and throw them on!
:biggrin:
SquadronOne.net
Post by Clayton »
good luck man those are a pain in the ass!!!!!!!!!!!!!!!
Post by rickles8099 »
i might have one laying around. i like to get extra suspension bolts when i go to the junkyard. problem is, my car is in pieces right now so it cant deliver it. also, try using a jack hammer on it along with soaking it in penetrating lube. also try using a propane torch on it.
HondaChild
rickles8099;45448 wrote:i might have one laying around. i like to get extra suspension bolts when i go to the junkyard. problem is, my car is in pieces right now so it cant deliver it. also, try using a jack hammer on it along with soaking it in penetrating lube. also try using a propane torch on it.
I guess rick let me know when you get your car together if I don't get another bolt before then.
Know your roots.
justin you were trying to take out the wrong bolt, you need to remove to two 12mm bolts on the car side. You never try to remove a bolt that MAY possibly be siezed like the one you broke the bolt on, always remove the one that bolts directly to the car. Don't worry about replacing it because it will never fall out and will be to much of a pain in the ass to remove
99BlackHatch;45445 wrote:Get on the back of it and break the "welded" nut off... Go to home depot and get a matching nut and bolt for what you need and hell while you're at it, get money somehow and buy LCAs and throw them on!
:biggrin:
this only works on LCA's
Burnz
Post by Burnz »
N2HIFI;45457 wrote:justin you were trying to take out the wrong bolt, you need to remove to two 12mm bolts on the car side. You never try to remove a bolt that MAY possibly be siezed like the one you broke the bolt on, always remove the one that bolts directly to the car. Don't worry about replacing it because it will never fall out and will be to much of a pain in the ass to remove
Ok thanks for the info.
-Justin on Burnz's name
99RedCivic
Post by 99RedCivic »
I've got that bolt if you still need it...extracting it looks like a pain in the ass.
-Lucas
Burnz
Post by Burnz »
99RedCivic;45474 wrote:I've got that bolt if you still need it...extracting it looks like a pain in the ass.
I will be sure to let him know that you have what he is looking for man. He's gone right now, I'm not sure where he went though.
