Pulling to the left
Preludedriver
Pulling to the left
Hi, I have a 98 lude with new pads roters and calipers when I got done putting all that on the front I took it for a test drive and the brakes got hot really quick and it's pulling to the left again like it used to. Oh and I just got an alinment done not 3 weeks agO. If anyOne thinks they know whats wrong let me know thanks zack
Daddy_Danglez
Pulling to the left
Did you properly prime the calipers with fluid? If no one of them could have seized up.
Pulling to the left
What kind of pads and rotors did you use? Why did you replace the pads and rotors? Was there any abnormal wear on the old pads or rotors? How are you figuring out that the brakes are hotter then they should be? Is the car only pulling to the left during braking or all the time?
Preludedriver
Pulling to the left
i had my roters spun and used the some $19.99 pads and blead the brakes but my dad says my brakes arn't the problem anything else that would cause the pull?
Pulling to the left
If you just did your brakes and nothing else it's most likely an issue with the brakes or wheel.
Unless you did something stupid like jack the car up by its tie rod or other suspension component.
Just curious why does your dad say that.
Pulling to the left
We can't help you if you don't answer all the questions we asked.Preludedriver;280495 wrote:i had my roters spun and used the some $19.99 pads and blead the brakes but my dad says my brakes arn't the problem anything else that would cause the pull?
Rich
Pulling to the left
A fat chick in the right seat might help this issue
2008 Chevy Slobalt
Hope this helps
Hope this helps
02Type-S
Pulling to the left
Caliper is prolly seized
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
2002 Acura TL-S
