brakes
gcef89
brakes
well to start off i was driving the other day and my brakes were not working i could push it all the way to the floor so i bled the brakes worked fine for awhile then it started again anyone know what the problem could be? all stock besides rear integra disk brakes but ive been driving fine with those for about 3 years and this just started happening yesterday!
gcef89
brakes
i checked for leaks but havent seemed to find anyrickles8099;272484 wrote:have you checked for leaks?
is the area below your brake fluid reservoir wet?
have you had to add any brake fluid to the car?
area below break reservoir is not wet
and i only had to add a little bit, when i brake it pulls to the passenger side
brakes
is it a rear drum set up? if it is i am throwing my guess as to bad wheel cylinders
95_gsrfodo
brakes
it is pulls to he pass side it could mean leak in the driver side so the pass side is working and the driver isntgcef89;272488 wrote:i checked for leaks but havent seemed to find any
4 Doors = More Whores
bks
brakes
Its more than likely not the prop, our brake systems are diagonally proportioned.gcef89;272504 wrote:im thinking its the prop valve since one side works and the other doesnt and neither side is leaking they compress but it doesnt seem like its compressing enough
If it pulls, look into a stuck caliper. Also, I'd pull the front wheels and check the caliper slider pins.
