wheel bearings
blueandy
wheel bearings
Post by blueandy »
Anyone done a wheel bearing replacement? I wanted to know if the bearing need to be pressed before i buy them. Any help is appreciated.
crx08
wheel bearings
Post by crx08 »
details on the car would be helpful. just saying
stl-imports.com/forums
gsrauto98
wheel bearings
Post by gsrauto98 »
would also help if you're doing the rears or front?
Team NOCO crew member #3 :devil:
blueandy
wheel bearings
Post by blueandy »
Sorry about that. 92 si , rears , I'm thinking they have to be pressed but not for sure.
andyjt
wheel bearings
Post by andyjt »
blueandy;231849 wrote:Sorry about that. 92 si , rears , I'm thinking they have to be pressed but not for sure.
No. Bolt's on.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
crx08
wheel bearings
Post by crx08 »
andyjt;231867 wrote:No. Bolt's on.
i concur
4Door
wheel bearings
Post by 4Door »
^^^^ yep... just need basic tools...
H.E.A.R.T
blueandy
wheel bearings
Post by blueandy »
thanks for the help
wheel bearings
Post by Capt'n Obvious »
i can do it cheap i do wheel bearings all the time
though you dont need a press you still need to know what your doing
blueandy
wheel bearings
Post by blueandy »
One more question? I dont have a damn clue if the wheel bearing i need should have the abs ring or not. When i did my front half shafts the originals didnt have the abs gear ring but maybe someone replaced them before me and went cheap on it. Pretty sure i can pop the ring off if not needed but the there is a price difference betewwn abs and non-abs
