anyone here locally bought these? this is quoted from MFactory
Too bad they only make it for civic and integra's
MFactory Extended Ball Joints
Gain an advantage over the competition on both Track or Strip with the MFactory Front Extended Ball Joints.
By extending the ball joints by 0.75", the MFactory Front Extended Ball Joints realign the front lower control arms on lowered vehicles, thus increasing the vehicles roll stiffness and eliminating any unwanted side-effects to the vehicles suspension geometry. The result? Increased traction both in a straight line and through a corner.
Increases Steering Response & Stability
Increases Traction & Helps to Eliminate Wheel Hop
Perfect Alignment = Less Stress to Drivetrain Components
Helps to reduce those 60ft times!
Includes Zerk Fittings for simple maintenance of ball-joints
- Track-Tested & Proven on our 950whp 9sec SFWD Drag Car -
mine will be on this weekend but the car will still be down. i spent 160 on them from kingmotorsports.com the mfactory were more expensive but did have a zerk fitting for easy lube but the retaining clips were just in a weird location if you notice there like an inch from where they should be so i went with the buddy club ones i wish they were offered in different lengths for fine tunning purposes because not one car is the same. i suggest if your a hard paker though you could spend your money else where just saying.
