Squealing Sound = New Brakes?
Dan The Man
Post by Dan The Man »
Quick question, I think i have an idea of whats wrong but before I order the wrong parts I need opinions.
A few days ago I started hearing a slight squealing coming from the front right wheel when driving on the highway. Every day I hear this sound more, and now it occurs when I'm driving around town too. The sound goes away while I apply pressure on the brakes, and goes away for a few minutes if I apply harder pressure.
I'm guessing this noise is coming from the brake pad wear indicators, but does the fact that it stops when I brake suggest it's a bad wheel bearing? Any info you know would be great. Thanks.
team NOCO crew member #4
Currently Taking A Break From The Game
Post by rickles8099 »
its the brakes.
gsrauto98
Post by gsrauto98 »
edit: therick beat me
Dan The Man
rickles8099;220587 wrote:its the brakes.
thank you sir
johnny94
Post by johnny94 »
A wheel bearing usually grinds. A good way to rule it out is to jack the car up and grab the top and bottom of your wheel and rock it, if it moves there is a good chance you need a bearing.
Phughes
Post by Phughes »
check breaks or bearings
Rich
Post by Rich »
Just put wheel bearing grease on your pads - no more squeaking
You may have to increase your braking distances however :yelrotflmao:
2008 Chevy Slobalt
Hope this helps
