lcas and height
97slvrhatch
lcas and height
so i put new springs on my civic and the front sits low but i would like the back to be lower. would aftermarket lower controls arms help any?
tbrazzy-s3
lcas and height
97slvrhatch;219688 wrote:so i put NEW SPRING on my civic and the front sits low but i would like the back to be lower. would aftermarket lower controls arms help any?
Elaborate. As to what you just put on your vehicle.. And as Rob so eloquently stated, new LCA's will not be helping you in your quest for "moar LOWER".
v-tecivic
lcas and height
ditch the springs and get coilovers. then you can put the ride height as you see fit.
97 civic ex turbo
13.1@112
02Type-S
lcas and height
This.v-tecivic;219733 wrote:ditch the springs and get coilovers. then you can put the ride height as you see fit.
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
2002 Acura TL-S
lcas and height
cut a coil
some kinds of aftermarket struts will lower it a lil
v-tecivic
lcas and height
.matt;219904 wrote:cut a coil NO!
97 civic ex turbo
13.1@112
lcas and height
It compromises the spring rate and reduces the handling potential of the car.matt;220055 wrote:why not?
lcas and height
oh im sure these springs are not performace oriented anyway lolJustRob;220115 wrote:It compromises the spring rate and reduces the handling potential of the car.
