^^^ this coming from you, bitch please.99BlackHatch;173169 wrote:OMG...shut up. It's like you always have to prove someone wrong about something.
Good write up, I have seen this before. I wish I had all the components to do this as well, but sadly, my car came without it when I purchased it.
JustRob;173203 wrote:You have to have a reservoir with fluid in it to keep the rack lubricated. Thats a part of ANY power steering delete when using a power rack. The only way to completely delete the entire power steering system is to swap in a manual steering rack. So yes, this is a DIY power steering delete.
Good work. I would have done things a little different but if it works, it works. And you're having no leaks with those lines?
o fucking well i was wrong whipty fucking do.
