4040 prop valve, non abs?
DC_T
Post by DC_T »
Ok, sorry if i've overlooked this somewhere, and this may sound dumb, but how can you tell if a prop valve is non-abs vs abs? about 3 years ago i was at the junkyard and i saw a 94-97 integra so i pulled the mc/booster and prop valve. at the time i didn't really know what i was looking for i just knew that eventually i'd like to have an integra disk swap on my hatch and i knew i'd need this stuff. well, now i am looking to actually do that so i dug out these old parts and i can't remember if the teg was a non-abs one or not. but, the prop valve has 6 inlet/outlets and is stamped 4040 and the master cylinder is stamped 15/16. so, am i dealing w/ non abs stuff here? or how can i tell? i've tried searching the random number on the booster and mc but no luck. anybody know?
thanks
andyjt
Post by andyjt »
DC_T;162993 wrote:Ok, sorry if i've overlooked this somewhere, and this may sound dumb, but how can you tell if a prop valve is non-abs vs abs? about 3 years ago i was at the junkyard and i saw a 94-97 integra so i pulled the mc/booster and prop valve. at the time i didn't really know what i was looking for i just knew that eventually i'd like to have an integra disk swap on my hatch and i knew i'd need this stuff. well, now i am looking to actually do that so i dug out these old parts and i can't remember if the teg was a non-abs one or not. but, the prop valve has 6 inlet/outlets and is stamped 4040 and the master cylinder is stamped 15/16. so, am i dealing w/ non abs stuff here? or how can i tell? i've tried searching the random number on the booster and mc but no luck. anybody know?
thanks
Thats NON-ABS then.
ABS integras dont have prop valves and have 1in Master cylinders.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
DC_T
Post by DC_T »
andyjt;163001 wrote:Thats NON-ABS then.
sweet! i guess i got lucky then when i was pulling this stuff off. thanks man.
