Tell that to my rear tires which HAVE proper TOE yet still has uneven wear on the inside of the tire.RyanA;186826 wrote:FYI: Negative camber is not the killer of tires. Improper TOE is. A properly aligned car with negative camber will not wear tires on the inside like everyone thinks. I'd get a proper alignment and you will probably be just fine.
camber kits
SweetEBPSi
camber kits
98_gsr
camber kits
I had this problem too...toe was in spec but tires were getting eaten. Got a camber kit and no more issues
92egsnatch
camber kits
Camber does eat tires just slowly...If you dont rotate them properly. Rotating your tires every other oil change is what is suppose to be done.
camber kits
stfu92egsnatch;212864 wrote:Camber does eat tires just slowly...If you dont rotate them properly. Rotating your tires every other oil change is what is suppose to be done.
andyjt
camber kits
Tire rotations helps equalize tire wear from driven to undriven wheels / vise versa. It doesnt effect any tire wear angles.92egsnatch;212868 wrote:?
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
92egsnatch
camber kits
Yeah but tires chop out due to lack of roatation.
koolkid420
camber kits
i havnt payed for an alignment in a while. My tape measure and a good eye take scare of it. No tire wear.
