camber kits
camber kits
Post by Capt'n Obvious »
Tweaked;186817 wrote:Yea it takes an hour or 2 to install.
i dont see how it could be more than 15 minutes unless you have a spinning ball joint
twistedaffection
camber kits
Post by twistedaffection »
ok so my friend has a 91 integra with really bad camber, we got the kit now just to install it. are there any tips anyone can help with?
luvmyhondas
camber kits
Post by luvmyhondas »
Parts Slingin' Hobo RyanA;186826 wrote:FYI: Negative camber is not the killer of tires. Improper TOE is. A properly aligned car with negative camber will not wear tires on the inside like everyone thinks. I'd get a proper alignment and you will probably be just fine.
this man speaks the troof! as well as Mike93. most people don't know this little tidbit.
camber kits
Post by mike93hatch »
and i taught that to ryan ages ago..hahahah i remember it was a good argument..
Devil Crx
camber kits
Post by Devil Crx »
recommendations on where to get a lowered car (mycar) alligned? or any place can do it?
*GMR* CRX Superleggera
camber kits
i go to firestone soley because of the lifetime alignment
been there bout 15 times i was satisfied once i would not recomend going there if you plan on getting it done once
ksingh2463
camber kits
Post by ksingh2463 »
get that TOE adjusted.. no need for camber kit
camber kits
when in rome
camber kits
matt;211553 wrote:when in rome
Yes? Please go on.
camber kits
if you have a kit use it
