Official Post Your Suspension Setup Thread!
Midori
Post by Midori »
Lol
-'11 Taffeta White CR-V
sn95guy
Post by sn95guy »
92 Eg Hatch
Goldline Springs
Front and Rear Upper Strut Braces
1995 Mustang Gt- Bolt ons and spray R.I.P.
1992 Honda Civic Cx, Swapped, suspension, Wheels
Soon- 97 Cobra- Procharged 12lbs, full exhaust, gears, drag radials...
sn95guy;112596 wrote:i want mine to sit that low... looks really good
well you will need to spend a decent amount of money on a GOOD QUALITY suspension , along with some mild modification of the inner fenders.
my coils are almost all the way down, i can go about a 1" lower but i would have to switch to 195/50/16's series tires and pull my fenders to be able to still turn lock to lock
Post by Capt'n Obvious »
wow bringin this back from the dead
nex full coilovers
10kg/mm spring rates
26mm front sb
19mm rear sb
es poly sb bushings
rear disks
The red coupe is long gone so heres the new coupe. Just a simple setup now.
-Omni Power Drag Spec Full Body Coilovers (12k Fronts, 18k Rears)
-Blox Rear Lower Control Arms (Black)
Eventually I'll add a Carbing 3-Point Strut Bar w/ Master Cylinder Brace but that will be it.
Post by bildo16 »
i recently sold my function and form type 1's to "asdf" and picked up a set of Buddy Club N+'s. Lol, i also sold my progress sway+tie bar and i am probably going to pick up DC5R rear sway bar pretty soon.
N2HIFI;84319 wrote:Image
current:
Kyb Agx 4 way adj (4 front 3 rear )
GC coil overs
Block Rear LCA's
Skunk2 Front adjustable UCA
GSR rear sway bar
APC Front Strut tower bar
Upgrading to :
ST front swap bar
GSR Lower control arms with ES inserts (have just need to install)
NRG 4 point lower tie bar
GSR front sub frame brace
ASR rear subframe brace
Type R rear sway bar
Bloxs ADJ end links
Beaks lower tie bar
Rear disc brake conversion
Nrg or carbing 3 point front Strut Tower bar
Rear Strut tower bar
C-pillar bar
6 point roll cage
well alot of that changed lol
-currently on the EG
Kyb AGX's
Ground Control Coilovers
Spoon upper Strut tower bar
Sustec lower tie bar
GSR lower control arms with ES bushings
GSR front sway bar
Blow Rear lower control arms
Asr rear brace
beaks lower rear tie bar
and i love everything about the suspension it's slammed and handles great FOR ME
better pic
RSXSLVR79
Post by RSXSLVR79 »
Prelude-unknown, but most likely stock springs with about a coil cut from them
Accord:
KYB AGX Adjustables
Ground Control Coilovers (Spring rates are 200 front, 230 rear)
Ebay STB
Energy suspension front sway bar bushings
Nothing special, but definately more fun than the stock 4x4 stance
01 S2000 (Stock...for now)
SweetEBPSi
Post by SweetEBPSi »
Ground Control coilover sleeves
Tokico Illuminas 5-way adjustable shocks
Skunk2 front camber kit
Rear camber kit (not sure of the name)
Stock Si front strut bar
Megan Racing rear strut bar
Megan Racing rear lower tie bar
No picture of it.
Post by 90CivicEx »
Skunk2 Pro's
Skunk2 Forged Top Hats w/ES bushings
Blox Rear LCA's
ES Sway Bar Links/Bushings
DA Spindles
CRX Forks
Not a current pic of the car but the suspension is done here, only difference is the car is actually painted now and raised about a inch, At least the header is but you can't really tell outside the vehicle.
