Skunk2 lca's
Skunk2 pro series front camber kit
Skunk2 rear camber kit
ASR rear lower subframe brace
ITR 22mm rear sway bar
Function7 solid rear sway bar bushings
Blox adj. end links
EX front lca's
ST 25.4mm front sway bar
NR>G 4 point front lower tie bar
Benen Tripod front strut bar
TDM X-Bar
Gram Lights 57 Optimise ceramic white 15x6.5 +38
Toyo Proxes T1R 205/50/15
Still to install:
Integra trailing arms with rear disks/stainless brake lines/Mugen TA bushings
