DIY: Power Steering Delete OEM Parts Free! 3rd gen tegs
integ2000ls
Post by integ2000ls »
Ok, sorry for the crappy pics, but this may help some if interested.
Well I have seen a few of these threads on here and other places, but its hard to find one that was completed. (At least that I could find.) This allows you to get rid of the ugly/extra unneeded lbs of a power steering system using all of your parts on ur 3rd gen teg.
What you will need-
*Nothing but tools and power steering fluid!
My high pressure line busted on me, causing a big mess. So since I was thinking about pulling it off anyways, this confirmed my choice.
First, of course you can start by removing the power steering belt, pump, and pump mounts, and resevor/resevor mount .
Next you can unbolt the hard lines located here that are held on by 3 10mm bolts.
Then Cut the soft line connected to those hard lines on the bend shown here.
Then you can remove the entire line.
Next you can take out this bolt located on the sub brace holding the hard line high pressure line coming out of the rack where the steering knuckle is.
Then you will loosen this bolt that holds the hard line into the rack shown here.
Then you can take out the high pressure line.
Now everything is out. And in my case, the hight pressure line was the one that busted on me. So I just cut the line and pulled the bolt off of it to reuse. (If you dont want to do that, then just find a bolt that will go back in the rack and that is hollow.)
Now you can put the bolt back in and tighten it up.
Then you will have to bend the OEM resevor mount to fit onto the hole from the bolt that you took off of the sub brace that was holding the hard line on it. Also make sure to give the mount enough bends to clear any brake lines or what not.
Then slide the resevor on the mount, and hook this lines back up to the rack from the resevor. This is how I did it.
Then just turn the wheel to release any unwanted fluid. After it stops filling back up in the resevor (if it does it) then fill the resevor back up with fluid until both lines are plenty covered up so they dont suck air in.
And you are done, check for leaks and retighten if needed. Here is what it looks like when looking behind the intake manifold from the top. Out of sight, while still functionable.
v-tecivic
Post by v-tecivic »
nice write up! i've seen other ones where they use an extra clutch reservoir for the fluid.
kra95civic
Post by kra95civic »
actually this is more of a relocation D.I.Y. since you actually are using the resevor a delete would acctually mean that its gone no longer to be used. in technical terms. but very goop pics and nice write up.
kra95civic;173150 wrote:actually this is more of a relocation D.I.Y. since you actually are using the resevor a delete would acctually mean that its gone no longer to be used. in technical terms. but very goop pics and nice write up.
He did delete the PS pump and any working PS system.
kra95civic
btlfedgolf;173153 wrote:He did delete the PS pump and any working PS system.
OK so its a power steering pump delete and reservoir relocation.
integ2000ls
Yeah I see what you're saying. I just kept the resevor bc a lotta ppl have said it makes it easyer than just looping the lines.
99BlackHatch
Post by 99BlackHatch »
kra95civic;173156 wrote:OK so its a power steering pump delete and reservoir relocation.
OMG...shut up. It's like you always have to prove someone wrong about something.
Good write up, I have seen this before. I wish I had all the components to do this as well, but sadly, my car came without it when I purchased it.
SquadronOne.net
Silver Knight
Post by Silver Knight »
99BlackHatch;173169 wrote:OMG...shut up. It's like you always have to prove someone wrong about something.
lets do it on mine!! boosh!
DC5
IshbOO
Post by IshbOO »
my power steering is gone.. but the guy who did it didn't do a very good job. I am wanting to reinstall power steering maybe, and to do so, i gotta install a new steering rack :x
94 Teal DC4
You have to have a reservoir with fluid in it to keep the rack lubricated. Thats a part of ANY power steering delete when using a power rack. The only way to completely delete the entire power steering system is to swap in a manual steering rack. So yes, this is a DIY power steering delete.
Good work. I would have done things a little different but if it works, it works. And you're having no leaks with those lines?
