wiring up claytons drag car.
crimsoncivic
So when u say burnt Down u mean?
Sarcasm. Obviously the car didn't burn down.crimsoncivic;293044 wrote:So when u say burnt Down u mean?
yup, just a piece of wire about 8" long.Phate;293045 wrote:Sarcasm. Obviously the car didn't burn down.
Edison Carasio
BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
I wanted to see some chaos god dammit. I demand blood!
crimsoncivic
lol sorry burnt down to me means fire engulfing the body and everything is....TOAST ..but glad to hear that my definition was not what happenedPhate;293045 wrote:Sarcasm. Obviously the car didn't burn down.
stupid ecu is throwing a code 15 "ignition output signal", it does it with two different ecus and i tryed a different ignitor, so my only assumption is that the distributor itself is bad. it starts right up and idles great, it just stumbles when you hit the gas.
i have one i am going to try to bring over tonight.stolle;293490 wrote:stupid ecu is throwing a code 15 "ignition output signal", it does it with two different ecus and i tryed a different ignitor, so my only assumption is that the distributor itself is bad. it starts right up and idles great, it just stumbles when you hit the gas.
yowza it sounds mean i cant wait to play with it.
