obd2 lude obd1 engine
overboost7845
Im going to install a h22a1 from a 93 into a 1998 sh prelude. Can I just rewire the obd1 distributor and use the factory ecu and pass emissions still?
96ludesi
Your going to have to do a CKF bypass, and you can use your old ecu and be just fine.
overboost7845
correct me if im wrong but im pretty sure the prelude doesn't even have a ckf sensor. thats only on civic and integra96ludesi;286592 wrote:Your going to have to do a CKF bypass, and you can use your old ecu and be just fine.
