Cluster fu*k
TheDoc
Cluster fu*k
Post by TheDoc »
97 hx auto
All parts swaped from the same 99si
b16a2
trans
p2t ecu
shift linkage
cluster
Engine wiring harness from a 97 ex (man. trans)
Obd2a-obd2b harness from rywire
I paid a shop to install my wiring harness and noticed after install that two wires were clipped and now my odo, speedo and tac are nonresponsive. I need a wiring guru and I'm willing to compensate for time.
Cluster fu*k
Post by RyanA »
Fuel gauge and temp still work or are all cluster functions dead? The HX auto kind of throws a little crap in the mix as it used a CVT controller separate of the ECU IIRC. You may need to compare the green plug pinout on the HX harness to the green plug pinout on the EX harness and also do the same for the driver side strut tower plug. You'll probably see a few differences but the ones you are interested in would be VSS and tach obviously.
If I was local, I'd help out. However, there are plenty of others in the STL area that are just as competent (if not more) as I.
