is there any way you could text me? i cant post pix im never on the internet and i usually cant post pix:/ if not ill try to get a friend to take the pixstolle;244904 wrote:can you take a picture of the parts you have and post it?
the fuel line is maybe 10" long with banjo fittings on either side, it could possibly still be attached to the fuel rail with a large nut. the only way to tell is if you take the fuel line off of the fuel rail and look at the holes in the banjo fitting one will be larger than the other, thats the difference between the dx and si fuel lines. the dx line has holes that are the same size, so if you use a dx line on a si fuel rail it will not allow enough fuel to pass through and starve the engine for fuel, if it even runs at all.
Dpfi to mpfi?
HatchGirl89
Dpfi to mpfi?
Dpfi to mpfi?
Your gonna need a mix of things....HatchGirl89;244906 wrote:is there any way you could text me? i cant post pix im never on the internet and i usually cant post pix:/ if not ill try to get a friend to take the pix
Si manifold "a6 or z6 there are others but these are the easiest to find"
Fuel Rail to match either
Intake manifold Gasket "Best to get the intake gasket to match the car it came from rather it be z6, a6, y8 etc.
Fuel Line to match either
Throttle body "which ever you use make sure you use the gasket for that Throttle body cause the y8 for example is made different from the z6 but have the same bolt pattern."
Obd-0 Injectors "you can use obd-1 just gotta shave one spot so the clip pops on"
Obd-0 wireing harness "Easy this way you dont have quite as much wireing to do."
Pm6 ecu obd-0 ecu
Resistor box
MPFI Dist from a a6 motor since the plugs on the dpfi dist are completely different.
Oh yeah make sure you get the mpfi spark plug series since it's actually different from the dpfi's
Here's the wireing fun:
http://honda-tech.com/showthread.php?t= ... conversion
My minds escaping me cause I know I'm missing something.
HatchGirl89
Dpfi to mpfi?
alright thanks90CivicEx;244936 wrote:Your gonna need a mix of things....
Pm6 ecu obd-0 ecu
Resistor box
Dpfi to mpfi?
you dont need a harness, you need the injector clips, other than that you only need to add 4 wires to the dpfi harness, 2 injector wires and 2 wires for the ckp sensor. a whole lot easier than getting an entire harness.90CivicEx;244936 wrote:Obd-0 wireing harness "Easy this way you dont have quite as much wireing to do."
Dpfi to mpfi?
yup, its inside the mpfi a6 distributor.91beatuphatch;245050 wrote:crank position sensor.
HatchGirl89
Dpfi to mpfi?
ok how can i tell i have that?stolle;245052 wrote:yup, its inside the mpfi a6 distributor.
Dpfi to mpfi?
the mpfi distributor will have 7 wires in it and a round plug, a dpfi ditributor has 5 wires and a square plug.HatchGirl89;245075 wrote:ok how can i tell i have that?
HatchGirl89
Dpfi to mpfi?
ok ill have to look tonight at it and see i hope sostolle;245077 wrote:the mpfi distributor will have 7 wires in it and a round plug, a dpfi ditributor has 5 wires and a square plug.
