whats the best ecu for obd1 ls/vtec?
justme5424
I just recently acquired a completed ls/vtec and i'm wondering what ecu's would work with an obd1 car? It'll be going into a 94 del sol which is currently running a p28. Thanks in advance guys
90 Honda CRX HF
-B16A Turbocharged
-B16A Turbocharged
crx08
OBD-1 ecu's would work with a OBD-1 car. i assume.justme5424;220621 wrote:I just recently acquired a completed ls/vtec and i'm wondering what ecu's would work with an obd1 car? It'll be going into a 94 del sol which is currently running a p28. Thanks in advance guys
stl-imports.com/forums
justme5424
sorry i meant best ecu for ls/vtec on an obd1 car. sorry for the confusion
90 Honda CRX HF
-B16A Turbocharged
-B16A Turbocharged
crx08
Silver Knight
ding ding ding! one of the best obd1 ecu's out there. don't get rid of that ecu. chip it (if you haven't already) and put the basemap you want on it. drive it. have fun.crx08;220626 wrote:probably the P28 that you already have.
DC5
Any USDM OBD1 ECU. Chip it. And get it tuned.
p72
but if you already have a p28
lstyrluder
I have 01 prelude and want to get the obd1 conversion... All i need is the p28 ecu and harness and then just install ?
crx08
you will need to find a OBD-2 to OBD-1 jumper harness. and have the ecu tuned for your H22lstyrluder;225072 wrote:I have 01 prelude and want to get the obd1 conversion... All i need is the p28 ecu and harness and then just install ?
lstyrluder
