Knock Sensor Wire In
runsonrice
Does anyone have a pin that i could use to wire in my knock sensor to the ECU plug?
Junkyard would be the easiest way to get one. Just pull a few pins and put them in your pocket.
ive got some if you mean the plug...
exactly, I'll be going to the junkyard saturday prolly and I'll swipe some.mike93hatch;148140 wrote:ive got some if you mean the plug...
OR why don't you just have your ecu chipped to eliminate the knock .. you don't need it anyways .. specially if your running cams and getting tuned anywaysrunsonrice;148131 wrote:Does anyone have a pin that i could use to wire in my knock sensor to the ECU plug?
He doesn't wanna have to spend the money to buy the kit for the jdm p30 y0.N2HIFI;148176 wrote:OR why don't you just have your ecu chipped to eliminate the knock .. you don't need it anyways .. specially if your running cams and getting tuned anyways
Also I put a pin in and wired it up and it ran a bit longer but then boom cel 23....tis a never ending thing it seems. Both right up's we have found for the wireing diagram for a p28 and p30 and searching h-t states that the knock senser pin is located in D3 well we put it there and no such luck.
Your doing it just like this...90CivicEx;149163 wrote:He doesn't wanna have to spend the money to buy the kit for the jdm p30 y0.
And I thought Cale bought cams?
Skunk 2 stage 2 pro's but he needs to upgrade the valve train first, he's looking into a ferra or supertech valve train.SilverStreak;149165 wrote:Your doing it just like this...
And yes I got the pinout from http://www.phearable.net/tech/
Then just tell him to chip it then. LOL Its only $20! Plus hes going to need it in the near future anyway. Jeez.90CivicEx;149167 wrote:Skunk 2 stage 2 pro's but he needs to upgrade the valve train first, he's looking into a ferra or supertech valve train.
troof, but I haven't chipped a ecu yet. I've reburnt chips and retuned my car, but haven't set a socket yet but then again could be a good learning experience. It shouldn't be that hard I watched stolle and rick do it and I have made chipsets for computers in college so how hard could it be.SilverStreak;149169 wrote:Then just tell him to chip it then. LOL Its only $20! Plus hes going to need it in the near future anyway. Jeez.
