manual versus automatic ?
Midori
is there any difference in ecu's if it came out of a car that was available in both manual and automatic but the motor was the same?
-'11 Taffeta White CR-V
Kage87
i think they are different :dunno:MidoriMiller;67574 wrote:is there any difference in ecu's if it came out of a car that was available in both manual and automatic but the motor was the same?
-Kyle
"Le Bon Temps Viendra"
Yes there is, I am not sure whats different but you cant put an auto ecu into a manual car unless you chip to be manual or something. Pm Rickles8099 bc hell know what to do to an auto ecu to make it a manual.MidoriMiller;67574 wrote:is there any difference in ecu's if it came out of a car that was available in both manual and automatic but the motor was the same?
Jar Jar Binks
yes they are different
TurboFreak
boostedEX has a auto ecu in his car which is a 5 speed and it jsut throws some sort of tranny code but no biggy just the cel light will be on
Nik
Turbulent Motorsports
I have more torque than GOD!
NevermindTurboFreak;67649 wrote:boostedEX has a auto ecu in his car which is a 5 speed and it jsut throws some sort of tranny code but no biggy just the cel light will be on
you have to move some resistors/jumpers around, its easy if you've soldered before.
search the pgmfi.org forums
"quick description.
remove RP17 leave open, remove RP18 and install jumper in PR18 location. "
"quick description.
Midori
the ecu i need for my swap is a needle in a hay stack so if i decide to give up on it im wondering if i could use an integra LS obd-2 ecu to fire a B20B..
you getting that stuff from jj?MidoriMiller;67724 wrote:the ecu i need for my swap is a needle in a hay stack so if i decide to give up on it im wondering if i could use an integra LS obd-2 ecu to fire a B20B..
Midori
sshhhh yeah we sent the block to button today.. then its getting assembled it will be a while before it goes in i still need a transmissionbildo16;67731 wrote:you getting that stuff from jj?
