Really need a tune?? 98 Civic with B18C and couple bolt ons.
Post by RyanA »
Just curious if I really need to retune my car. I'm guessing so since the IAB is gone now. Here's what's done:
B18C (P72)
DC 4-2-1 1 piece
2.25" exhaust
Password JDM whale dong
S2 Pro Series intake manifold
That's it engine wise. Would a retune make this thing come alive or not? Pulls like crazy from 6k to 8500 for a nearly stock engine.
Ryan
Silver Knight
Post by Silver Knight »
why would you need a tune? now if you had some cams, upgraded pistons, valve train, then yeah i could understand if you wanted a small street tune but for what you have now there is no need unless you want to waste you money.
DC5
modthesol
Post by modthesol »
Silver Knight;53632 wrote:why would you need a tune? now if you had some cams, upgraded pistons, valve train, then yeah i could understand if you wanted a small street tune but for what you have now there is no need unless you want to waste you money.
+1 dont waste ur money just yet
Post by Gunmetal Si »
modthesol;53639 wrote:+1 dont waste ur money just yet
that guy waste money, not a chance!!!!
Post by RyanA »
lol, Dale. Just figured I'd check to see. Wasn't sure if not having the IAB anymore would lean the fuel curve below their opening point. Car feels fairly strong for now but I'm sure I"ll be used to it in 10 or 15 minutes....
Ryan
JVolsch
Post by JVolsch »
On my B18c1 I had essentially the same mods as yours. It was previously tuned on uberdata, and I had it tuned with neptune rtp by superdave. After the tune I had a very noticeable difference. The mid range prior to the rtp tune was terrible. Afterwards it was extremely flat, and it gained a large amount in that range +10-15hp. Prior to the tune it was also falling flat on its face, so that was also fixed.
civicex442
Post by civicex442 »
JVolsch;53666 wrote:On my B18c1 I had essentially the same mods as yours. It was previously tuned on uberdata, and I had it tuned with neptune rtp by superdave. After the tune I had a very noticeable difference. The mid range prior to the rtp tune was terrible. Afterwards it was extremely flat, and it gained a large amount in that range +10-15hp. Prior to the tune it was also falling flat on its face, so that was also fixed.
+1
98 EJ6
03 WRX
Post by RyanA »
Cool. Thanks for the update. I got a stock ITR ECU and it definitely pulls better on the big end. Seems about the same down low but smoother. It will have to do until.... .....Well until I hopefully pick up this B18C5 to put in the car in the next couple days.
Ryan
alowfodo
Post by alowfodo »
trading the guy for all the k-series stuff?
Post by RyanA »
Well, would have but I think he's re thinking his position on it. I think maybe he's figuring out what it takes to do the swap. This isn't just the old B swap...
