Stolle chips awesome ecu's by the way. Both my ecu's are chipped by him and I havent had one problem since.brettk7;23478 wrote:thats dam decent man! i wish this would have been around when i had my CRX!
free ecu chipping !!!
95_gsrfodo
kra95civic
wish i had a honda to do that with...i guess im out....
95_gsrfodo
yay over 200 post free ecu chipping here i come.. once i find my ecu lol
4 Doors = More Whores
do it!!!91turbo;27860 wrote:yay over 200 post free ecu chipping here i come.. once i find my ecu lol
btw did you know you can convert your current p06 ecu to a p28?
95_gsrfodo
is it a po6 in the car? d15b7? i have no idea but i did see the vtec add on kit and then buy the chip can u do it all stolle? ill get the vtec add on and ship ave u do the vtec add on run the motor to break it in put the turbo onm the ad the chip?/
yes its a p06 to order the vtec add on you will have to pull the cover on the ecu find what board number you have. if your holding the ecu so that the plugs are pointing up the number will be on the right and will look somthing like this "02d01720-1500" the numbers in bold are the numbers your concerned with. yes i can do it all as far as soldering and a basemap, the rest is up to you...91turbo;27862 wrote:is it a po6 in the car? d15b7? i have no idea but i did see the vtec add on kit and then buy the chip can u do it all stolle? ill get the vtec add on and ship ave u do the vtec add on run the motor to break it in put the turbo onm the ad the chip?/
edit look at this:
http://www.xenocron.com/install/ECU-Board-Number.htm
95_gsrfodo
well after soldering and basemap whats left take it to get tuned? and dynoed?
yes, or tuned on a dyno or street tuned just tuned in general...91turbo;27864 wrote:well after soldering and basemap whats left take it to get tuned? and dynoed?
95_gsrfodo
ok well as i said i order the ship ill order the vtec conveesion and let ya know when i get it i wanta get this motor in asap so i wont wanta sell it
