trans wont go into gear at all after sitting a few days
ejtuner88
I have a '93 civic d16z6 with a crx dx trans in it. trans has 130,000 miles on it. i started hearing a growling noise that went away with the clutch engaged and was occasionally hard to shift so i figured it was the throwout bearing. well the other day i parked it to do some suspension work and when i went to take it for a test drive a few days later it wouldnt go into gear at all. I just replaced the bearing (that did show alot of heat damage) and its doing the exact same thing. its full of fluid, clutch pedal feels fine and the fork didnt look bent at all. any ideas?
gcef89
maybe syncro's? is your trans auto? if so does it have the shift lock release? what fluid did u use?
ejtuner88
no its a 5 speed car. im using mobil 1 75-w90 gear oil it works alot better than mtf.
you should be using regular 10w30 motor oil.ejtuner88;270115 wrote:no its a 5 speed car. im using mobil 1 75-w90 gear oil it works alot better than mtf.
gcef89
genuine honda trans fluid is suppose to be the best but u can use regular 10w-30rickles8099;270124 wrote:you should be using regular 10w30 motor oil.
online honda manual says otherwise:gcef89;270132 wrote:genuine honda trans fluid is suppose to be the best but u can use regular 10w-30
http://media.honda.co.uk/car/owner/medi ... 00/8-2.pdf
to op, how long have you been using the gear oil?
ejtuner88
i put it in when i first converted it, then put honda mtf in it. but the gear oil seemed to work pretty well. but it started grinding with the mtf in it.
Those service manuals are now nearly 20-years-old. Honda has recommended using Honda MTF in all M/T equipped vehicles (Except the Passport) since '96. Using 10W-30 is fine, however Honda MTF is a better fluid as it reduces wear and noise.rickles8099;270124 wrote:you should be using regular 10w30 motor oil.
I don't understand where people get the idea to put fluids like 75W-90 in their transmissions. It is not better then Honda MTF.
