Clutch problem...
LEGEND
Clutch problem...
So my clutch finally went out today. Can't get the car to move at all. Ive already ordered an exedy clutch kit and new flywheel. Now tgat tge clutch is blown my clutch pedal falls down when i touch it, but u have to push with all ur strength to move it down a half inch to turn the car on. Is this normal wirh a blown clutch or do i have further problems such as the master/slave cylinders. Never had an issue with pedal falling and not coming back up intall the clutch blew
1993 Acura Legend LS 6spd Coupe
Clutch problem...
Look at your clutch master cylinder, is there fluid in there?
I've never had a problem like this before, but it sounds like to me theres air in there, or maybe no fluid.
Clutch problem...
or some kind of mechanical failure keeping the clutch from disengaging.
like something in the way of the throw out bearing
LEGEND
Clutch problem...
Im hoping it mechanical...rick is fixing my clutch/flywheel. Wouldnt wanna have to replace the cylinders too. Dunno how they could of gone bad all a sudden when the clutch blew
LEGEND
Clutch problem...
update:
Rick informed me at was indeed a bad cylinder....the slave cylinder
